Old 27th June 2005, 17:17   #16
Rtech's Avatar
Thanked: 221 Times
Originally Posted by EVO6
In the Skoda 1.9TDI on the in-dash computer its shows about 0.8-0.9lts/Hr when idling and AC on ....
Wierd. It shows me 1.0-1.1 lts/hr with the AC on and 0.8 lts/hr without the AC.
Old 27th June 2005, 20:40   #17
v1p3r's Avatar
Thanked: 27 Times
@epyupc...I'm not really sure, but it could be that someone could have a cold/insensitive nose. So then they wouldn't necessarily smell the gases, but still inhale them. Also I suppose the better the car runs, the less gases come out. Thus the quantity required to smell them may not be reached, but over a period you could still die inhaling.
btw...superb bike, bro! what speeds were you hittin when you took off? how quick is the 100 run?
Old 27th June 2005, 21:34   #18
z klasse's Avatar
For every 3 mins the car idles with the a/c on it looses 1 km of drivable distance.
Source: Times Drive
Z
z klasse is offline   Reply With Quote
Old 27th June 2005, 22:21   #19
autopsyche's Avatar
Thanked: 15 Times
epyupc, the exhaust gas consists of various gases, it is the unburnt hydrocarbons that you can smell, CO is basically odourless.
rtech my skoda shows 0.4l/h without ac and 0.6l/h or sometimes 0.7l/h with ac
autopsyche is offline   Reply With Quote
Old 27th June 2005, 22:22   #20
normally_crazy's Avatar
Thanked: 394 Times
it shows 0.6 ltrs/hr with the ac on - on my trip computer !
normally_crazy is offline   Reply With Quote
Old 28th June 2005, 00:20   #21
epyupc's Avatar
I guessed that it would be the impurities that one could smell.
Thats why I was curious how people accidently die from inhaling car exhaust in a closed room etc....
Like v1p3r said, could be wierd cases or long time exposure.
@v1p3r
I've done under 5.
Under 4 is possible, but difficult to keep the front down.
epyupc is offline   Reply With Quote
Old 28th June 2005, 01:52   #22
EVO6's Avatar
Rtech and NC,
We shud meet up once and just compare the reading at a go ...
Then maybe fight with Skoda as to why there is disparity....
EVO6 is offline   Reply With Quote
Old 28th June 2005, 03:35   #23
its possible that thre are alot carbon particles in the piston or the radiator must cloged with some dirt so less air gets in the piston or the timing of the valves must be wrong or the base rpm must have increased if there is a timing error my esteem had the same problem the base rpm was 900 a little timing adjustment would fix that
aazam is offline   Reply With Quote
Old 28th June 2005, 11:04   #24
karthik247's Avatar
Thanked: 16 Times
Thats really good Arush. My Skoda shows 7l/h without AC and 1.2l/h with AC!!
karthik247 is offline   Reply With Quote
Old 28th June 2005, 11:08   #25
Rtech's Avatar
Thanked: 221 Times
Thats more like it! NC, are you SURE it shows just 0.6 Lt/hr with the AC on???! That's real low.
Old 28th June 2005, 22:42   #26
amitverma's Avatar
thats unity in diversity right there for ya!
amitverma is offline   Reply With Quote
Old 29th June 2005, 10:26   #27
Thanked: 394 Times
Rtech ,
just checked the consumption figures again yesterday and today -
1) 0.6 ltrs/hr with the a/c on
2) 0.4 ltrs/hr without the a/c
by the way have you noticed how the consumption increases when you press the accelerator and the best part at 80 kmph if i remove my leg from the accelerator the consumption is 0.0 ltrs/hr - hehe ...going at 80kmph without using diesel !!
cheers
Where Time Still Stands Still - A Journey (Delhi-Dumka-Deoghar) anandjha Travelogues 11 29th November 2012 16:59
idling fuel consumption and pollution passionpurple Technical Stuff 30 28th September 2011 14:38
high fuel consumption in indica dls morten Technical Stuff 3 17th August 2006 09:32
best  and worst fuel consumption figure speedsatya The Indian Car Scene 66 25th September 2005 22:40
Diesel beats Hybrid in Fuel consumption test amit The International Automotive Scene 3 7th September 2005 19:31
