Old 26th June 2005, 22:41   #1
lamborghini's Avatar
Thanked: 1,664 Times
Default Alternative Sources of Fuel (including plastic fuel!)
Guys,
with the Fuel prices going sky high,
What other Alternatives do we have that can be produced cheap, not polluting, with no compromise in Performance and FE.
I am talking other then LPG and CNG.
lamborghini is offline   Reply With Quote
Old 26th June 2005, 23:16   #2
v1p3r's Avatar
Thanked: 27 Times
Super Reva.
There's this guy in America. Red Porsche. Tons of batteries. Does standing burnouts and shreds rubber. Easily keeps up with gasoline Porsches of the same model too. And you can't beat the instant torque of a DC motor.
Old 27th June 2005, 00:15   #3
Shan2nu's Avatar
Thanked: 89 Times
Yup, that's probably the best part about electric cars. Tab the pedal and all that toqure is right there, no matter what speed you're doing.
Ofcourse if you've got tons of torque, it can be a problem controlling it. You'll need some sort of a regulator which can vary the torque reaching the wheels, in order to control wheel spin.
Shan2nu
Old 27th June 2005, 01:56   #4
Thanked: 1,641 Times
Originally Posted by v1p3r
Super Reva.
Yes but you still have to produce electricity somewhere, right? That means either (1) Flooding places (2) Burning gas (3) setting up a nuclear plant or other such means which still create some form of pollution or use up fossil fuels elsewhere...
Not really an alternative, unless you have access to energy that isnt dependent on fossil fuels at all.
Steeroid is offline   Reply With Quote
Old 27th June 2005, 09:52   #5
DCEite's Avatar
Thanked: 607 Times
What about Biodiesel Guys... lotsa research going on... (especially in my college )
read more here:
http://www.dceonline.net/biodiesel_research_at_dce.htm
Picture of college principal's BioDiesel (official) Car:
DCEite is offline   Reply With Quote
Old 27th June 2005, 10:20   #6
Conan's Avatar
Smile
My physics professor used to say that one of these three,
will end all energy shortages of mankind,
1. Nuclear Fusion.
2. Superconductors at room temp.
3. Solar energy with feasible efficiency.
Coming to cars, some of the alternatives are,
1. Hydrogen based. (Fuel cells)
2. Molasses/Ethanol based. (By product of Sugarcane industry)
3. Biodiesel based.
US, India and China are moving towards hydrogen based economy.
South American countries which produce lots of molasses are moving
towards Ethanol based economy.
And European union is exploring biodiesel and hydrogen based.
I feel fuel cells are the way to go.
PS : LPG/CNG are still fossil fuels and wont be available after 10 - 15 years.
Conan is offline   Reply With Quote
Old 27th June 2005, 10:20   #7
AGP
Thanked: 67 Times
Hydrogen is the ultimate fuel that can be used which can produce almost zero pollution as the products of the hydrogen burning is only water vapor. In Japan it is commercialized. In india Banaras Hindu University is working on engine development for hydrogen as a fuel. But only concern is that how to produce hydrogen? If we go for steam-reforming which uses natural gas to produce hydrogen, it produces CO2 which is not tolerated as it cause global warming. So only alternative for less polluting hydrogen production is Solar, Nuclear or biomass. And the process development for all these sources are under progress. Hope by 2020 we have a mature developed process for hydrogen production
AGP is offline   Reply With Quote
Old 27th June 2005, 14:38   #8
Insane Devil's Avatar
Thanked: 164 Times
I think BIO-DIESEL will be the next thing we will get, coz all over india, the government is putting up lot of land under farming , growing Jetropha. (in case if someone missed out where biodiesel comes from - Jetropha plant) In Andhra Pradesh, aroudn 2.5 lakh acres is being put to cultivating Jetropha. it will be around 15-20% cheaper than regular diesel i suppose.
Insane Devil is offline   Reply With Quote
Old 27th June 2005, 15:50   #9
v1p3r's Avatar
Thanked: 27 Times
@steeroid, flooding places is the most viable. Pollution is non-existent in that case. Also nuclear power: amount of waste generated per generated kW must be MUCH less than coal etc. Could live with it for a few years/decades.
@shan2nu, yeah, the torque makes the reva unbeatable in stop'n'go traffic. That's why the porsche guy got those wheelspins. Easiest way to regulate such loads would be through viscous coupling, as used in heavy-duty industrial applications.
Old 27th June 2005, 15:53   #10
typeOnegative's Avatar
Thanked: 20 Times
Is not in my opinion. Hydroelectric power has its own way of damaging the eco-system. Nuclear power may produce lesser waste in terms of weight, but in terms of danger to life it is far too risky. Personally, solar power and fuel cell technology is what looks most attractive to me.
typeOnegative is offline   Reply With Quote
Old 27th June 2005, 17:52   #11
veyron1's Avatar
Thanked: 38 Times
IMHO, the alternatives could be;
1) hydrogen-fuelled internal combustion engines- could run with a separate reservoir, for rapid electrolysis of water into hydrogen and oxygen; the power source for the electrolysis will have to be li-ion or fuel cells, as high voltage is required for rapid disintegration. it takes almost 85KWH of electricity to generate 1 kg of hydrogen- but the calorific value is way higher than any fossil fuel, even ATF (air-turbine fuel).... actually, i had some designs in mind for a hydrogen powered car ( the engine), but....no resources, and some guy in iceland is already trying to implement my idea....he..he..
2) solar powered D.C induction motor/ A.C motor, that would run as hybrid-powered, with the help of fuel cells or high-amp efficient li-ion batteries (no I.C.E's). the thing is, although D.C motors produce max. torque at zero r.p.m, they are less efficient than a/c motors...
and as for the myth about electric cars not being fast, there was this guy, who ran an electric car with a d.c motor, with 6000 (!!!) 1.5v AA size batteries as fuel, in the salt lakes.... and he clocked 240 mph+.....
veyron1 is offline   Reply With Quote
Old 29th June 2005, 02:55   #12
hey lambo listen the best thing to do in india is to get an electrical car which can be recharged normaly and through solar pannels though hydrogen internal combustion engines are great but in india we dont have the tech to do it
aazam is offline   Reply With Quote
Old 29th June 2005, 03:56   #13
Mpower's Avatar
Thanked: 1,687 Times
I saw a news report that HM re-launched the CNG Amby and they are claiming that cost per km is only Rs.1.25.
I wish more companies offer CNG vehicles and more CNG outlets be made availabe to the public.
Old 10th September 2005, 02:23   #14
Thanked: 59 Times
not to mention the unsolved problem of nuclear waste disposal. Most countries are just leaving it to the future generations to worry about it.
hell_rider is offline   Reply With Quote
Old 10th September 2005, 14:57   #15
pranil's Avatar
Default warrenty on New CAr
Does anybody have a idea if a LNG/CNG kit ( off course installed by a licensewed fellow) wil invalidate the manufacturers warrenty or not
pranil is offline   Reply With Quote
Choosing the right- Hotels / Resorts / Home stays from sources - tripadvisor reviews girishglg Shifting gears 13 21st June 2016 08:52
Sources for Vintage & Classic Car Parts/Accessories/Restoration Services DKG Vintage Cars & Classics in India 36 21st July 2014 10:34
Power cuts: alternative power sources MillionSwords Shifting gears 46 16th January 2013 16:30
*Attached* : Fuel cost calculator, including a comparison between Petrol & Diesel Delta Wing The Indian Car Scene 131 1st March 2012 13:33
Alternative Fuel Options !! man23ish The Indian Car Scene 31 31st July 2008 12:12
