Old 29th July 2009, 14:11   #1
yogi1771's Avatar
Default Fiesta 1.6 - Hissing sound
Members in my car when I press the accelerator there is hissing sound,did check the air filter by disconnecting the plumbing but still the sound is present any idea what could be causing this sound.
yogi1771 is offline   Reply With Quote
Old 29th July 2009, 14:17   #2
nitrous's Avatar
Thanked: 285 Times
Driveshaft or Speedo cable.
Old 21st August 2009, 15:40   #3
yogi1771's Avatar
Well the sound which was emanating from the engine bay turns out to be from the throttle body and is normal did check it out other 1.6 cars at shaman including a brand new one.
Facing a new problem though recently had been to Mahableshwar the car was running fine till Pune but after that could fell the loss in power the car was not responding well while pressing the accelerator any ways reached till Wai but halfway to Panchgini on the ghats the car was not accelerating at all,stopped the car for a few seconds cranked it and the car was running again but still the car was not performing 100%.After reaching Panchgini the car was parked for a few hours and the car was running fine again 100% and the drive back to Mumbai was non eventful,but Yesterday while idling with ac on the car was running for about 5mins and all of a sudden the car stopped with a shudder cranked it again after a few a few secs and the car was running again.Members any idea what could be the problem looks like the fuel pump is acting up.
Old 21st August 2009, 15:53   #4
suman's Avatar
Thanked: 257 Times
Yogi, how many Kms has your car done?
Old 21st August 2009, 15:58   #5
Jaggu's Avatar
Thanked: 8,670 Times
Good idea to check the air filter, fuel quality, fuel filter and the ignition pack. Last will be to check the fuel pump.
Old 21st August 2009, 15:58   #6
yogi1771's Avatar
Suman not much 22k only.
Old 21st August 2009, 16:00   #7
vnabhi's Avatar
Thanked: 1,309 Times
I suspect it is a problem related to bad quality fuel, but I may be wrong. Generally we refuel on roadside bunks on the highways, and those are not always known to stock clean fuel.
Old 21st August 2009, 16:09   #8
yogi1771's Avatar
Jaggu recently had the air filter changed so that is ruled out,as regarding the fuel the car was tanked up in Mumbai itself.
Hissing sound from speakers when not playing music. Please help. vishnuvijay In-Car Entertainment 62 12th March 2016 15:17
Whatzatt Noise (Hissing sound) greenh0rn In-Car Entertainment 7 26th December 2009 15:04
Hissing sound in NHC Vtec naman Technical Stuff 6 15th August 2008 17:20
Slight Hissing sound from ICE meconi In-Car Entertainment 9 29th January 2008 10:18
Hissing sound from belts in my Avalon adityapd Technical Stuff 17 29th September 2007 08:39
