Old 28th June 2005, 18:35   #1
Revvhead's Avatar
Default Baleno Air intake
Hi guys.
Had to remove the air intake of my baleno today to be able to access the Headlight bulbs ( I have upgraded to 100w for the monsoons) and was a little confused by the design.
As it is i was trying to figure out the flow,
For those of you who have one, there is a "scoop" in the front of the airbox, which thenleads into the wheel whell, then from ther back into the airbox!!!
(Sorry no pics, i cant find my camera docking port!!!)
any idea why its so convoluted?? why not have the opening straight into the airbox since the airbox and the scoop are attached together.
Why is it routed the long way around?
Any ideas
rant:
and why the hell are the lights so inacessible
had to take half the car apart to reach the lights
Revvhead is offline   Reply With Quote
Old 28th June 2005, 18:45   #2
Shan2nu's Avatar
Thanked: 89 Times
This is gotta see. Any pics?
Shan2nu
Old 28th June 2005, 18:51   #3
Revvhead's Avatar
Hunting around teh house for the damn port,
i need to tranfer phot's and cant for the life of mr find the docking port!!
The moment o find it the pis will be up
Old 28th June 2005, 19:23   #4
Revvhead's Avatar
Here are the pics
Old 28th June 2005, 20:05   #5
Shan2nu's Avatar
Thanked: 89 Times
Yup, that is a wierd design.
In the OHC the intake pipe starts just before the front right suspenssion and has the box behind the engine.
Shan2nu
Old 28th June 2005, 23:54   #6
Revvhead's Avatar
WHat is the secong pipe in the pic, the one that stops and seems to be open ended just next to the engine
Old 29th June 2005, 08:47   #7
Revvhead's Avatar
Ok Guys, i have decided that the K & N under my bed needs to come out,
Now what i need is some advice on the install,
I was planningto do a complete cold air intake setup,
But cash flow problems are kinda hampering that idea.
So, i thought that i'd just bolt on my Universal K&N conical filter
Any ideas on how i can minimise the Hot air from the engine bay coming into the filter??
i was planning to route it to the location of where the airbox is currently
Iceman- any advice
Old 29th June 2005, 10:20   #8
iceman91's Avatar
Thanked: 22 Times
that box is designed that way to avoid water and dirt from getting in. it works pretty well though!!!
k&n i have sent you a p.m.
iceman91 is offline   Reply With Quote
Old 30th June 2005, 10:10   #9
Revvhead's Avatar
Thanks Iceman,
Well the K&N is now well and truly bolted on!
there is a definite change already, but the sound is very muted
compared to the lovely roar it used to give in the matiz!
Old 1st July 2005, 21:12   #10
Mpower's Avatar
Thanked: 1,687 Times
That looks like an intake resonator. Where its stops, its blocked off.
Old 1st July 2005, 21:23   #11
Shan2nu's Avatar
Thanked: 89 Times
Yup, the 2nd pipe is blocked off at the bottom. but, what exactly does a intake resonator do?
Shan2nu
Old 1st July 2005, 22:59   #12
Mpower's Avatar
Its supposed to quieten the intake roar of the engine. On 2-stroke bikes it was claimed to increase power and cure flatspots (the infamous RTZ "power-box" and later both Shogun and RX-135). Dunno how much of that was true.
When you do a CAI, usually you throw away the resonator and then you can really hear the intake noise. I think Zen was the first car with one. That one was shaped like a small square box.
Old 1st July 2005, 23:06   #13
Shan2nu's Avatar
Thanked: 89 Times
No wonder the car sounds awesome when ever the the service guys revv the engine while cleaning the intake.
Shan2nu
Air filter and Air intake sunilvarma Technical Stuff 10 4th November 2010 10:58
Diffrence between an ordinary cold air intake and a ram air intake?? Vys De BlUR Technical Stuff 24 1st April 2008 12:59
Best air filter or cold air intake for Skoda RS Kartik9500 Modifications & Accessories 9 7th February 2008 03:43
WOW!! Check the air-intake on this Vtec! GTO Shifting gears 4 18th April 2004 14:53
MercMc SLR Air Intake Rehaan Technical Stuff 7 10th April 2004 15:40
