Old 3rd August 2009, 18:46   #1
Unhappy Mileage Problem (Accent CRDi) after Scheduled Diesel Engine Purge!
My Accent CRDi's was scheduled serviced at 58000 kms from Hyundai Service Center. I get my services done at regular 8000 kms intervals. Besides regular parts changed such as diesel filter / oil filter / air filter / engine oil etc. I got de-carbonizing with Wynns diesel engine purger.
After the service/purge was done, i clocked 2000 kms more and I found some problem with the mileage, which has drastically dropped to 8-10 kmpl on Highways. This bothered me a lot and I took my car to service center, where they cleaned the fuel injectors and catalytic convertor at 60000 kms. Since my car was not emitting any black smoke before and after the service is done.
Now at 63000 kms done the problem remains the same. Mileage!
Please guide some solutions!
Thankyou!
(PS: pics are attached, please excuse for low resolution)
Mileage Problem (Accent CRDi) after Scheduled Diesel Engine Purge!-abcd0004.jpg
Mileage Problem (Accent CRDi) after Scheduled Diesel Engine Purge!-abcd0002.jpg
Mileage Problem (Accent CRDi) after Scheduled Diesel Engine Purge!-abcd0003.jpg
Mileage Problem (Accent CRDi) after Scheduled Diesel Engine Purge!-abcd0001.jpg
sizoo is offline   Reply With Quote
Old 3rd August 2009, 19:16   #2
was the decarbonizing done at service center and is wynn's recommended by service center??
mean while check for turbo pipe leaks.
and with same imp. check for the Solenoid Purge Control Valve,
check if the injection pump seals are broken, do you smell diesel.??
Thomas8700 is offline   Reply With Quote
Old 7th August 2009, 11:29   #3
athalaga's Avatar
Thanked: 18 Times
Some more pointers are required here, regarding any change in feel, mileage before, any other changes etc
athalaga is offline   Reply With Quote
Accent Viva Crdi: Purge Control Solenoid Valves - Rs.16.5k! EDIT: Fixin it DIY style! AbhiJ DIY - Do it yourself 64 11th December 2014 13:38
Lancer DIESEL/ Accent DLS/Accent CRDI ForeRunner Sedans 28 20th June 2011 18:19
Sluggish Accent CRDI after engine rebuild. clipto333 Technical Stuff 30 10th March 2008 23:44
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
