Old 10th March 2006, 19:30   #16
kvish's Avatar
Thanked: 135 Times
Default Does climate control help fuel efficiency
Hi Folks,
Cars with climate control basically switch off AC when temperature is ok and switch it on only when needed (correct me if I am wrong) automatically. So you dont end up fiddling around with the A/C controls.
Question is has anyone done a comparison of climate control vs fuel efficiency. As per explanations, it should .....but....???
kvish is offline   Reply With Quote
Old 10th March 2006, 20:59   #17
aZa
aZa's Avatar
Thanked: 17 Times
I think its just a digital thermostat compared to the normal red/blue one on none climate control systems. the compressor switches off in normal AC units too but u can't feed in a temp reading for it to switch off at. just like normal and digital home ac's i feel. as for the FE part .. i dont really know
Old 10th March 2006, 23:27   #18
aah78's Avatar
Thanked: 1,627 Times
Arrow Climate Control does not save fuel....
you need to understand how these systems work before you know which one saves more fuel....
Basic Air Conditioning:
in a regular car air conditioning system - you manually set the temperature dial to various degrees of blue & red depending on how whether you need cold air or warm air to flow in the cabin.
the volume of air-flow is controlled by the position of the fan selector switch.
in addition, you have a manual selector which directs the air-flow towards the windscreen, floor or cabin of the vehicle.
depending on the levels to which the switches/dials have been set, the air conditioning unit pumps out cold air constantly (hot air, if heat is selected, in which case the air conditioning compressor is Off).
as the interior temperature drops (or rises), one has to adjust the settings to attain a proper temperatures.
Climate Control:
a climate control system is an advanced air conditioning system. it allows the user to pre-set a certain temperature in the vehicle cabin and accordingly it alternatively pumps in hot and cold air to keep the temperature level. ultra-violet sensors are installed to detect ambient temperatures.
a climate control system will always have an Auto function - when desired temperature is selected by the user, the system automatically varies the amount air-flow throughout the vehicle. a directional flow selector and a fan speed selector are also installed - in case the user desires to reduce air flow or direct air flow towards certain parts of the cabin.
climate control systems have an ECON or AC-Off button which kicks-down operation of the system so that the system operates only above certain temperature levels. however, the system is always On - unless completely shut-off using the Off switch..... thus, fuel is always being consumed by the system (less when the ECON switch is activated).
while an air-conditioning system occassionaly kicks-off the compressor when temperature lowers below a certain level, a climate control system constantly uses the compressor and heater to maintain air flow. as the compressor is constantly On, more fuel is consumed...........
an excellent description on Climate Control and Air Conditioning has been given here - Ford Scorpio - Air Conditioning
aah78 is offline   Reply With Quote
Old 10th March 2006, 23:37   #19
Rehaan's Avatar
Thanked: 22,610 Times
Kvish - Threads Merged,
Please use the Search function before creating a new thread.
cya
R
Old 11th March 2006, 07:55   #20
Thanked: 9,744 Times
In the swift, yhe climate control, not only controls temp but directs airflow as appropriate. It is direct air to both face and feet but after a while cuts off the feet once set temperature is met
Old 11th March 2006, 10:51   #21
kvish's Avatar
Thanked: 135 Times
cya
R
Ooops sorry about it!
Old 13th March 2006, 18:16   #22
Xsailor's Avatar
[/url]
To the point, simple and Sweet - Excellent write-up aah78.
Trust that will clear-up the doubts for a lot of fellow members.
My two cents : Do not confuse the car AC with the standard room AC; the above is one of the most important differences. In a room AC, the compressor does cut-in/out and help in power saving.
Stay Cool - Cheers
Xsailor is offline   Reply With Quote
K&N and fuel efficiency - Suzuki Swift shuhaib Modifications & Accessories 173 12th March 2014 06:28
Amazing fuel efficiency from my Swift abhaybakshi Technical Stuff 17 15th November 2012 20:39
Be a hero and Save the Climate at UN Climate Summit in Copenhagen December 19th serpente Shifting gears 0 27th November 2009 20:49
Swift ZXI Climate Control not working at 18C skiddyrow Technical Stuff 10 18th January 2007 14:56
