Old 3rd June 2015, 12:30   #46
Thanked: 19 Times
Default Re: Swift AC Problem
Originally Posted by Jaggu View Post
Wecool Tobias 080 25364270 just off Garuda mall/Margrath Road. You will have to go with the same type of compressor that came with the car, since putting a different model would require more parts to be changed and hence more cost.
Prices keeps on varying, just take the car there so that they can find out the make and model and confirm back on current price.
Thank you for sharing the contact details will contact wecool.
Also the reason I am confused about the compressor type is because 2 of the AC mechanincs suggested that I go for piston type compressor as rotary types are know to fail early and also are not repairable but the other way round, seems that the piston type gives better life and also in case of problems they can be repaired.
Please suggest guys.
Thanks,
Vijay
vijay_k is online now   Reply With Quote
Old 3rd June 2015, 12:59   #47
Jaggu's Avatar
Thanked: 7,469 Times
2006 Vxi i have a feeling it would be normal piston type compressor. Variable geometry came later with diesels IIRC, longevity part am not very sure, but variable ones are more efficient and saves fuel.
Jaggu is online now   (1) Thanks Reply With Quote
Old 3rd June 2015, 14:57   #48
Thanked: 19 Times
Hi Jaggu,
Thank you for all your inputs, will try to get the variable geometry once.
Vijay
Old 16th March 2016, 18:01   #49
Thanked: 30 Times
Originally Posted by vijay_k View Post
Hi Jaggu,
Vijay
Hi Vijay,
is there an update on this issue ? I'm going through the same problem with my swift 2005 model and i require some information on what fixed your problem and where you got it fixed. Thanks in anticipation.
ravigop is offline   Reply With Quote
Battery problem or starter problem or....?? Srinivas Technical Stuff 21 16th June 2017 14:06
Caliper Noise Problem - Common Problem But No Solution Yet vigsom Technical Stuff 48 17th July 2014 19:55
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
Problem with Swift Surprise Technical Stuff 16 25th January 2007 20:00
