Old 5th August 2009, 23:05   #1
greenhorn's Avatar
Thanked: 265 Times
Default Gearbox Oil Query - EP oils
My Indica user manual Recommends that I use Castrol Extreme Pressure 80 EP oil for the gearbox.
However, my TASC has used "castrol Transpower TQ" - cant find any info on this apart from the fact that it is recommended for the sumo.
Google tells me that using an EP oil in a gearbox not designed for it will cause damage.
In my case, the reverse has happened. Is there any risk?
Old 5th August 2009, 23:39   #2
jav
Even i could not find 80 ep oil for my indica when i changed my gearbox oil but i did add a few ml of my engine oil additive as it can be used for gearbox too (it was written on the can) and now my gears have become smooth
jav is offline   Reply With Quote
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 31 21st July 2010 21:42
How superior is synthetic oil over the normal 15W oils ? maxbhp Technical Stuff 7 25th September 2006 18:04
automatic transmission - gearbox oil change vinodbijlani Technical Stuff 9 24th May 2006 22:51
