Old 7th August 2009, 12:33   #1
genesis's Avatar
Thanked: 294 Times
Default Wobbling front tyre of palio 1.2 2002
Had my car tyres alinged, balanced a couple of months ago. They had also
adjusted the camber with a bolt at that time and had said that the tyres are
wearing out and have to be replaced. The place I usually get it done from is
pretty decent.
Recently the front right wheel feels wobbly when driving (even at low
speeds). If i stand in front of the car and ask my driver to drive it, i can see the wheel wobbling
Car is a 1.2 Palio 2002 with around 25k on it. Driven locally in Mumbai on horrendously bad roads (those who drive from Ghatkopar to Andheri thru Asalfa will be easily able to navigate surfaces on the Moon or Mars).
Before the tyre guy tells me it is the tyres and the mechanic tells me it is
the suspension arm wanted to see if people have experienced this before.
genesis is offline   Reply With Quote
Old 7th August 2009, 12:37   #2
Thanked: 49 Times
Could be a couple of things - The rim might be bent out of shape. Try replacing it with the spare wheel to rule that out. If changing wheels doesn't help then its the suspension that's damaged.
CrackedHead is offline   Reply With Quote
Old 7th August 2009, 12:42   #3
Thanked: 24 Times
My car too wobbles a bit, and tyres wear out unevenly.
My 2 front tyres were in bad shape, and had uneven wear, hence I put the back tyres front and started using the stepney and 1 new tyre was bought, hence now the tyres in the car are all good, but even then I feel a slight wobble.
My car has Alloys, can alloys be bent? or is the problem somewhere else, very diificult to locate the problem.
musicmanaman is offline   Reply With Quote
Old 8th August 2009, 16:54   #4
Thanked: 15 Times
Genesis,
I faced a similar problem on my Palio, but with rear wheels. Just run your hand along the outer surface of the tire at both inner and outer edges. If there are any irregularities then it means the tire has not worn out smoothly. This can also be the cause of wobble.
Have you also tired swapping the tires? (front & rear)
VeeTee is offline   Reply With Quote
Old 9th August 2009, 09:55   #5
Thanked: 29 Times
Check for tread wear. Swap the tires. Uneven tread wear could be due to driving for long duration with overinflated or underinflated tires either all or some of them. If I remember correctly, the PSI for Palio is 28 under normal loads and 30 under higher loads.
Also check wheel alignment at a good place.
Seeler_Rebeiro is offline   Reply With Quote
Wobbling Palio psp62in Tyre & Alloy wheel Section 4 21st March 2009 16:33
Wobbling tyre recshenoy Tyre & Alloy wheel Section 2 8th August 2008 01:21
wobbling/vibration problem in palio 1.6 Rahulkool Technical Stuff 31 7th April 2008 14:48
Car wobbling from front. What can it be? adman77 Technical Stuff 26 20th March 2008 09:30
Front Tyres wobbling kailashnj Technical Stuff 16 13th November 2006 20:18
