Old 7th August 2009, 14:58   #1
SCH
Default NHC 2004 Locks problem
I have a NHC 2004 model and in decent shape, sometime back somebody fiddled with the driver side lock and spoilt it, on inquiring at the Company service Center, they told me all four locks would have to be changed and it would cost around 12K, instead I got a central locking fitted and it has been working fine for the last two years. Recently I have a peculiar problem that sometimes the lever comes back, and if I bang the door a bit hard it works fine, I got the MINDA service chap over and he says that it is due to the faulty lock, Can any body suggest that i would get these locks cheaper in Delhi and not from the *** and if it is advisable to go for them.
SCH is offline   Reply With Quote
Old 7th August 2009, 16:44   #2
Thanked: 89,158 Times
I guess it's only the keyhole that's damaged? Cheap solution = swap the front door locks i.e. fit the one from the front passenger door to the drivers, and vice versa.
Old 7th August 2009, 16:50   #3
SCH
Yes You are right, actually some one tries to open it in a parking lot and messed it up, I explained the same thing to a mechanic to swap it from the driver side to the other side, but he said it is not possible as it comes with a rod and all the locks are differently aligned, same was also told at the Honda Service center. I was thinking of purchasing a set from the kashmere gate market where you get Honda smuggled parts at half the cost, what do you suggest ? Earlier I had got the bearing of rear wheels changed from Honda smuggled parts, they costed me half the price and are running fine for the last 20 k km.
Old 7th August 2009, 18:11   #4
I'd go for OEM parts bought from the after-market. Am pretty certain that a popular car like the NHC should have a ready supply of parts.
New Honda City (NHC - August 2004, 68,000KM) - Engine Shakes On Startup - Need Advice anandpadhye Technical Stuff 9 19th December 2009 01:02
Honda CRV 2004, 2.4L, AWD, AT or NHC Automatic rhandle SUVs, MUVs & 4x4s 29 3rd May 2009 13:20
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
Bad smell after starting the car (NHC-2004) anandpadhye Technical Stuff 35 23rd August 2007 10:50
New NHC ZX GXi or used 2004 Skoda rider TDI? Sri_009 Sedans 10 17th April 2006 17:43
