Old 10th August 2009, 10:26   #1
Thanked: 41 Times
Default Indigo DICOR - Idling issues??
After the third service, I noticed a drop in the FE of my Indigo Dicor from 12.5kmpl to 11.7kmpl
Yesterday I noticed a strange thing - When the vehicle is stand still and clutch pedal pressed down, rpm is close to 1000 mark. This is the case even if the gear is in neutral. However, if I take my foot off clutch pedal with the gear in neutral, rpm drops down closer to 800 mark.
Can this be a reason for the increased Fuel consumption as most of my driving is in peak hour traffic and I have to operate the clutch frequently.
cnaganathan is offline   Reply With Quote
Old 10th August 2009, 17:43   #2
Thanked: 41 Times
Default Pix attached
Here are the pictures I took. The first one shows rpm with clutch pedal pressed down while the second one is when the clutch is released. Both were shot with gear in neutral.
Old 10th August 2009, 18:03   #3
greenhorn's Avatar
Thanked: 1,519 Times
was the AC on ?
could this be due to the AC/electricals load ?
greenhorn is online now   Reply With Quote
Old 10th August 2009, 18:41   #4
Thanked: 41 Times
Originally Posted by greenhorn View Post
was the AC on ?
A/C, electricals both were on fully in both cases. I tried both cases (clutch pedal pressed and released) with electricals and A/C switched off too - still the rpm when clutch pedal is pressed was higher than when it is released.
Old 11th August 2009, 10:56   #5
athalaga's Avatar
Thanked: 18 Times
was the AC on ?
Exactly my question too greenhorn.
the idle speed must not change if you are in neutral and the clutch is depressed, (the idle speed does increase when the AC is turned on).
Now that you say its not due to the AC I have one more query.
Is this the case everytime you try it or is it just your tacho variability.
athalaga is offline   Reply With Quote
Old 11th August 2009, 15:10   #6
anky's Avatar
Thanked: 107 Times
Cool Dicor same issues + more
Hi I have an lx dicor ( indigo) 2007 model I to notice the difference when cluth is pressed , I too have noticed the drop in FE to 12.5 and noticed the engine drinks coolant more faster than it should and the engine getting noisier than what it was 1 yr back.Power windows sometimes get stuck ... but on the whole the dicor engine is far better than the tdi and has great pickup and torque...Not trying to make any point just thought I share my expirence too...
anky is offline   Reply With Quote
Old 11th August 2009, 17:35   #7
Thanked: 41 Times
This is not tacho variability. I have tried at different times - when the engine is just warm and has run a few minutes, when the engine is hot after a short run and the engine is hot after a long run. It is always like this. And as I mentioned earlier, this is the case only after 3rd service was done.
Old 11th August 2009, 17:52   #8
im_srini's Avatar
Thanked: 399 Times
Assuming everything else being the same, the only difference would be that in one case you're spinning the gears within the gearbox & in the other, you're not. With the clutch fully depressed the engine's isolated from the transmission, so the only load on it would be the A/C & alternator.
In neutral, with your foot off the clutch, the engine's still spinning the gears inside the gearbox. So the extra drag could be reducing the idling RPM a bit. Maybe you could check if they forgot to fill the gearbox with oil (been known to happen !) in case it was drained for replacement. Before your service, what were the idle RPM like, was it 800 or 1000 ?
In any case, from the pics, the difference appears to be very small...
im_srini is offline   Reply With Quote
Old 18th September 2009, 10:45   #9
Thanked: 41 Times
Default Wierd behavior - noticed a new one
Well I noticed a new wierd behavior two days back and verified it again today. Here is how it goes:
- Accelerate car to 60 kmph (4th gear) and then shift to Neutral
- Keep feet off all pedals and let car glide along.
- idle rpm stays close to 1000 (the way it is when idling with clutch pedal pressed)
- As speed drops to below 45kmph, rpm starts rising and when peaks at close to 1250 when speed drops to 35kmph!!
- Thereafter tacho stays close to 1000rpm till the vehicle come to a complete halt - irrespective of whether clutch is pressed or not
Questions:
1. Is this normal behavior? Has someone else observed this in their car too?
2. If this is abnormal what could be the issue - clutch, an ECU sensor or the ECU itself?
Some points to note:
1. Some Clutch components (IIRC - Release bearing and Pressure plate) were replaced FOC under warranty at 8k kms when I complained of a Hard clutch.
2. I do not remember such behavior prior to 3rd service.
3. Switched over to Mobil 1 Synthetic oil during 3rd service
4. Car has run 21k kms in 13 months and is handled by me mostly with an occasional drive by my driver.
5. Most of the run has been in city - peak hour.
Old 18th September 2009, 11:53   #10
DerAlte's Avatar
Thanked: 2,879 Times
@cnaganathan, you should be a Test Engineer for the auto manufacturers, since you seem to think of Test Cases which they might never have thought about! :
The ECU controlling the injection quantity at any point of time has at least about 20 different conditions to reckon with to calculate the injection quantity. Ironically, it does not know which gear, if at all, has been engaged - though it does know the clutch has been depressed, but not how much. There are conditions where the ECU has to predictively increase the injection to help the driver, like Uphill Start Assist in higher end vehicles. Such behavior is non-intuitive for most users, but normally has a technical basis. Maybe you could measure the RPM when trying to start the car uphill WITHOUT pressing the acc pedal (only on half-clutch)?
Idling issues in my Fiat Palio Radnam Technical Stuff 25 25th April 2012 09:25
2002 Honda Accord 4 cyl idling issues! aditya.86 Technical Stuff 10 21st June 2011 20:32
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
