Old 11th August 2009, 18:01   #1
Sha09mel's Avatar
Thanked: 7 Times
Default Damaged Sub Frame on NHC. Need Help!!!
Hi Freinds,
While servicing my NHC at Honda service station, it was brought to my notice that the SUB FRAME on the left side has been damged which would require to be changed completly along with the left lower arm.
After inspecting the car personally it was noticed that the Sub Frame was indeed damaged, not really sure how?? and it was also mentioned, if the sub frame & the Left lower arm are not changed soon it will damage the right lower arm of the car as well.
The price quoted to me for the Sub Frame is Rs8500/- and the lower arm Rs 3500/- each.
What I need to know, does it require to change the lower arm or just changing the Sub Frame would be sufficient and are the rates quoted justified.
Cheers!!!
Sha09mel is offline   Reply With Quote
Old 11th August 2009, 18:07   #2
ImmortalZ's Avatar
Thanked: 312 Times
Did you hit any potholes at high speed? Extreme shock damages the suspension and frame components.
Old 11th August 2009, 18:40   #3
Sha09mel's Avatar
Thanked: 7 Times
@I_Z : can't really recollect, but guess that could be the cause for the damage, keeping in mind the conditions of road during monsoon.
Old 14th August 2009, 11:51   #4
Sha09mel's Avatar
Thanked: 7 Times
Does anyone has a clue if changing the Sub Frame would be enough or should the Lower arm need to be replaced as well.
Old 14th August 2009, 12:48   #5
SCH
I guess both needs to be replaced if the damage is noticeable.
SCH is offline   Reply With Quote
Old 14th August 2009, 13:29   #6
It is difficult to say, depends on the nature of the damage. But it is highly likely that your lower arm is also damaged because when you hit a hump or pothole it is the lower arm that takes the hit before the Subframe.
Did you check other suspension components? A SubFrame will not get damaged so easily unless you hit something really hard in which case I am sure there would be some damage to the Strut, BumpStop, Strut Mount, Coil Spring or Drive Shaft as well.
novice is offline   Reply With Quote
Old 14th August 2009, 13:51   #7
Takumi-san's Avatar
I had hit a upscaled drainage cover , and when I mean upsized, it was like almost 1 foot above the ground. Maybe to prevent people from going in during the monsoon floods, but I couldnt see it while I took a U turn and consequently had the same problem. I suggest you replace it asap since it is a driving hazard too.
Takumi-san is offline   Reply With Quote
Old 14th August 2009, 16:18   #8
Sha09mel's Avatar
Thanked: 7 Times
Yeah!! guess I will have it replaced ASAP.
@novice; the damage to the sub frame is more towards the left rather then the centre of the car but seems I'll have it re-inspected with an authorised dealer again and may be get it changed.
@SCH: The damage is noticable to the Sub Frame but I didn't notice any damage to the lower arm inspite of standing below the car when it was raised to evaluate the extent of damage to the car
Minor accident - Was hit by a bus and left door damaged. Need help/suggestions drvhplyevraftr Street Experiences 22 19th April 2012 12:29
need gypsy soft top frame pics.. chargerman 4x4 Vehicles 1 22nd June 2009 22:54
To add Sub for NHC Vtec aks_karthik In-Car Entertainment 6 5th September 2007 16:05
City Driving NHC/NHC-CVT or Vtec Rahulk76 Sedans 7 27th April 2006 16:51
Nhc OR Nhc ZX unknown The Indian Car Scene 25 24th November 2005 10:15
