Old 12th August 2009, 10:29   #1
Default OHC Clutch noise - Help please
Hello BHPians ,
Atlast, after a long search(for about a year) i have finally bought my long awaited car, an Old Honda City, below are the specs
Make - Honda City 1.5 EXI (Old Shape)
Model - June 2002
Color - Heather Mist
Mileage on ODO - 70000 Kms
I seem to have a problem with the clutch noise and need help in understanding what could be the possible problem
Clutch, when pushed makes a screeching noise and seems to be a bit hard than normal. I took it for a check to one of the garage in JP Nagar Bangalore and was told that its a problem with the pressure plates making the noise and needs a replacement of the whole clutch.
As far my knowledge is concerned, i dont seem to have a problem in changing the gears, no slipping of gears or suddend rise in the rpm, which are more likely the symptoms of a worn out clutch (I might be wrong).
Questions
  1. What could be the possible problem (Pressure plates, Clutch disc, etc)
  2. Can an overhaul of release mechanism solve the problem
  3. If its a problem with the clutch, pls suggest how much would it cost to get it replaced.
Speedzone is offline   Reply With Quote
Old 12th August 2009, 17:31   #2
jav
Screeching noise usually is made by the release bearing when its worn out and needs replacement
jav is offline   Reply With Quote
Old 12th August 2009, 17:48   #3
alpha1's Avatar
Thanked: 1,035 Times
Instead of going ahead with some high cost repair/reaplacement - just oil/grease the clutch cable/sleeve, bearings etc.
I did mine and screeching went away.
Old 13th August 2009, 12:18   #4
Thanks for your suggestions
I managed to search thru some posts/theads on TBHP and found a couple of guys having similar problem.
The problem seems to be mostly duirng rainy season, as it dries up the Pedal hinges, spring and cables which actually makes the squeaking noise
Some of them have tried using WD-40 (lubricant) which actually has worked, but i'm not sure if its a long term fix or just a temporary one.
Anyone who has actually used it recently, pls suggest
  • How long does this last?
  • Does it need greasing after applying WD-40?
Old 15th August 2009, 02:24   #5
Thanked: 34 Times
Facing the same problem with my car Alto. Will take to service center next week. Any info will be great.
sbanerjee is offline   Reply With Quote
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Please Help Me for my c220 Cdi Brake Noise aviral2122 Technical Stuff 0 14th August 2009 22:15
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
