Old 28th March 2014, 14:37   #31
Thanked: 99 Times
Default Re: Starting and idling problem in Carb Zen
The UCAL electronic fuel pump (now manufactured by others like PTM, too), is simple, cheap and very reliable. It comes with its own fuel filter and tubing, as detailed in the Premier 118 NE thread, and can be used on any vehicle from the Maruti 800 to the Jonga 4000(cc), maybe even for higher capacity engines. It can be fitted anywhere after the petrol tank to before the carb. The only hassle the A.S.S. would have is to connect a wire for its power requirements, and it would have no 'side effect' on the electrical system. That is "pure bunkum" put out by the A.S.S. to discourage people for going in for cheaper (but as good) alternatives !
SnakemanJohny is offline   Reply With Quote
Inconsistent idling and engine shut off problem DCEite Technical Stuff 17 18th May 2012 22:37
Warming Up / Idling Engine before starting off... 911turbo Technical Stuff 29 23rd May 2009 13:02
maruti zen starting problem zenopio Technical Stuff 4 10th August 2007 17:30
starting problem of my zen zenopio Technical Stuff 2 14th February 2007 20:37
99'ZEN carb to ZEN mpfi.... Balram Modifications & Accessories 17 10th December 2006 09:04
