Old 19th August 2009, 19:47   #1
Thanked: 45 Times
Default Radiator cooling fan problem?
When i opened bonnet of my lancer diesel for changing oil and doing other things, i noted, radiator cooling fan not working, but instead when the temperature rises the AC condensor cooling fan is working, (it is on right side and just next to AC condensor) . But the temperature stands on near half in the meter, it stood same for all these years, I didnt notice that radiator fan not working all these days, instead AC fan is doing its job,
How can i check the radiator fan, whether it is fine or something gone wrong?
rajivanoj is offline   Reply With Quote
Old 19th August 2009, 23:05   #2
Thanked: 660 Times
thats strange. you need some wires if you are in to DIY. locate the fan connector, disconnect it and connect it directly to the battery. Do be careful about the polarity.
Old 20th August 2009, 08:52   #3
Thanked: 45 Times
okay..thanks, thats what i am worried about the right polarity, i think its better to get this to electrician
Old 20th August 2009, 10:03   #4
gpa
gpa's Avatar
Thanked: 282 Times
rajivanoj,
The a/c condensor fan and the radiator fan work independently of each other. When the a/c is turned on, the a/c's fan at the condensor will switch on and off depending on the speed of the blower in the cabin and the level of cooling.
The radiator fan will switch on only once the engine temperature crosses the optimum level. If you are idling your engine, then the a/c compressor fan will switch on more frequently than the radiaor fan.
I don't think you have a problem, bue get the circuitry of the radiator fan checked by an electrician.
Cheers,
gpa
Old 20th August 2009, 10:21   #5
Thanked: 45 Times
@gpa & siralec
Thanks for your inputs, i shall check the radiator circuit by an electrician.
Old 20th August 2009, 21:48   #6
Thanked: 45 Times
Problem Solved
Actually when the temperature exceeds permissible limit, both the radiator and AC cooling fan will spin for sometime till it reaches optimal level. In my case only AC fan was working (it may take twice the amount of time to cool).
Then i removed the radiator fan from car and checked with electrician, it was not working, so i asked to open it, the carbon brush worn out, so its not touching the armature, then i took that assembly to electrical shop, luckily Indica's carbon brush was right fit, but i got four instead on needed two. (Rs.180/four).
but fitting the brush inside assembly was much trickier, since Denso fan is sealed (may be use and throw type), so some locking parts got broke and atlast fitted the carbon in right place , but armature didnt go inside, so had grinded some part with file, then it fitted, anabond was needed to fix the broken lock. Atlast it was ready and zooming back to life.
total cost:
Indica carbon brush for cooling fan - Rs.180
Anabond - Rs,5
Labour - Rs.100 (took almost 4 hours)
If i have not chose this option, i would have gone for new fan which costs Rs.3500 minimum, So am happy that the electrician was good enough to find the fault.
Fan for 3rd row cooling in Scorpio mooza Modifications & Accessories 13 1st October 2011 15:31
Cooling fan in Car Amp. Ajaybiz In-Car Entertainment 28 19th January 2011 10:51
Palio 1.2 cooling fan failure and experience with roadside assistance Dr.AD Technical Stuff 10 30th April 2010 18:07
Strange problem with Petra - Radiator fan jraj Technical Stuff 8 24th August 2008 14:00
