Old 26th August 2009, 15:45   #16
Jaggu's Avatar
Thanked: 8,693 Times
@srini: This can be either due to the air inside the fuel filter OR if its mild its the typical diesel pitter patter/chatter which you need to live with.
Old 26th August 2009, 16:49   #17
athalaga's Avatar
Thanked: 18 Times
I think you need to get the opinion of a better mechanic to confirm if it is really knock. If the engine is really knocking you need to check your fuel -if there is any petrol contamination or if your fuel lines are blocked partially if it is not either of the two it is an injector issue.
athalaga is offline   Reply With Quote
Old 26th August 2009, 20:27   #18
Its happening in accelerating not holding the the accererator.Its 60km to 80 km speed very slightly hearing.More than 80km speed it will hearing normal.I HAVE CHECKED WITH MECHNICS HE TOLD ME ITS KNOCKING SOUND.ONCE AGAIN I HAVE TO CHECK MECHANICS, PLEASE SUGGEST ANY ONE IN CHENNAI
arun.sidhes is offline   Reply With Quote
Old 27th August 2009, 12:34   #19
teknophobia's Avatar
Thanked: 22 Times
Have you had your engine mounts checked? It sounds like there is some play in the engine mounts.
teknophobia is offline   Reply With Quote
Knocking Sound in Santro Vys De BlUR Technical Stuff 24 14th June 2009 20:38
Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI agm Hatchbacks 29 11th April 2008 22:56
Knocking Sound in Santro Vys De BlUR Technical Stuff 0 5th March 2008 18:38
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Knocking sound from the rear of my Santro psynaps3 Technical Stuff 7 20th April 2006 02:07
