Old 26th August 2009, 11:05   #1
Thanked: 25 Times
Exclamation Removing the engine oil for a few days - any concerns?
I own a Classic Car. I want to buy an Oil Filter and the Dealer is asking me for a Sample.
He says he will take it from me and look for it when he has the time.
Should I remove the Oil Filter and give it to him as it is a running car ?
P.S. I am asking because to take out the Oil Filter, I will have to remove the Engine Oil and the Engine may remain without Engine Oil for a few days.
Will it create any problem ?
Please help me as soon as possible. I need to remove the Oil Filter in around an hour or so if I have to remove it.
supercars is offline   Reply With Quote
Old 26th August 2009, 11:14   #2
ashthedivx's Avatar
Thanked: 22 Times
I don't see any problem in storing engine oil in a sealed can for few days if you can manage without car, indeed it will get you exact part you are looking for. Just don't crank the engine anyhow
However, let gurus pour in their advice as well.
Old 26th August 2009, 11:17   #3
Thanked: 25 Times
Thank You for your reply.
I am waiting more replies.
Old 26th August 2009, 11:17   #4
Thanked: 24 Times
I agree, should not be a problem as long as you don't crank the engine.
musicmanaman is offline   Reply With Quote
Old 26th August 2009, 13:54   #5
Jaggu's Avatar
Thanked: 8,686 Times
Just dont start the engine, ensure the shop guy keeps your filter safe also and no tampering. Otherwise you will have a stranded car without filter, if he fails to procure the filter.
Old 26th August 2009, 17:05   #6
athalaga's Avatar
Thanked: 18 Times
Leaving the engine without engine oil for a few days will not cause any problems as long as you dont start it
athalaga is offline   Reply With Quote
Old 26th August 2009, 17:14   #7
SS-Traveller's Avatar
Thanked: 11,628 Times
...the Engine may remain without Engine Oil for a few days.
Funny that the dealer wants to find your part in his own sweet time. If you trust the gentleman, sure, give him your filter - so long as he does not lose or damage it! Else, try some other dealer. You could post the specifics of the filter on this site and seek the bottomless resources of members here to locate a new filter.
Keeping the engine without oil has no problems associated with it, as long as someone doesn't try to crank start the engine. Maybe you should disconnect the battery too, if you have an overenthusiastic chauffeur who might unknowingly try to start the car.
Old 26th August 2009, 20:28   #8
What kind of car and year is it? You can most likley find the part numbers online.
avinaash.b is offline   Reply With Quote
TBTS - doubts & concerns!! racingmachine Motorbikes 21 9th January 2011 10:10
Oil check light glows in 118NE, AFTER removing key adhiraj Technical Stuff 4 31st August 2010 21:39
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
