Old 26th August 2009, 16:31   #1
mathewpn's Avatar
Default How to adjust idling of indica turbo V2
I would like to adjust the idling when the Radiator fan is on. Idling rpm when the fan is ON drops to 750 and causing a lot of vibrations to steering wheel as well the gear level. I am able to adjust the idle when the AC is ON/OFF.
Can somebody shed some light on this. I've contacted several TASC, but the response is " It is normal ".
RPM at idle ( AC OFF ) : 850
RPM at idle ( AC ON ) : 950
help !!!!
mathewpn is online now   Reply With Quote
Old 26th August 2009, 17:04   #2
Thanked: 245 Times
Originally Posted by mathewpn View Post
help !!!!
Its not a carburetor screw that you turn and adjust, its controlled by the ECU and cannot be done as a DIY.
Old 26th August 2009, 17:32   #3
mathewpn's Avatar
to my belief, there are 3 adjustments ( screw type ) with which we can adjust the idling ( idling when AC is OFF, idling when AC is ON etc ). But am not sure which one or which pair to turn to adjust the idle RPM when the radiator fan is ON. Any thoughts ?
Old 26th August 2009, 18:04   #4
Thanked: 42 Times
There is no reason why the idling should drop when the fan is ON. It indicates that the fan is putting excessive load on the alternator, causing the RPM to drop. This needs to be checked.
Your problem will not be solved by adjusting idling RPM. As such, there is no FICD for radiator fan!
sschivate is offline   Reply With Quote
Old 26th August 2009, 18:08   #5
greenhorn's Avatar
Thanked: 1,516 Times
Is this an FICD issue ?
Some details here
Yahoo! Groups
Yahoo! Groups
These should help
greenhorn is online now   Reply With Quote
Old 27th August 2009, 12:03   #6
teknophobia's Avatar
Thanked: 22 Times
Your idle speeds are about 100 rpm below normal in all cases, do get the FICD checked.
teknophobia is offline   Reply With Quote
Old 27th August 2009, 17:50   #7
mathewpn's Avatar
sure.let me get the FICD checked.
Old 27th August 2009, 20:42   #8
mathewpn's Avatar
@greenhorn, thanks a lot for the URL's . I've gone thorough it and it was of great help. I went by some tread from that groups and adjusted the black screw for the idling with AC off and the long rod from the actuator for the idle with AC ON.
This forum ROCKS
Cheers !!
Mathew
Old 27th August 2009, 21:44   #9
greenhorn's Avatar
you should join the indica usergroup as well then
Indica V2 Turbo - Turbo Failure abhik Technical Stuff 15 30th November 2017 17:24
Turbo's and one minute idling amit Technical Stuff 99 20th June 2012 22:19
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
Indica Turbo vs Non Turbo lbhavani Technical Stuff 0 5th September 2006 22:22
New Indica Turbo - is the turbo on? gakudva Technical Stuff 5 15th July 2006 23:00
