Old 26th August 2009, 21:56   #1
mclaren1885's Avatar
Thanked: 28 Times
Infractions: 0/1 (10)
Default Points to consider while modding a Naturally Aspirated engine.
We have a separate thread on how to "turbo/supercharge" an engine. Thought it would be better to have a separate thread to discuss the pros and cons of doing a NA build.
Let us not get into the details of how much power an air filter, spark plugs, wires etc make, for that we have the 25bhp bolt on thread. Let this thread serve us for discussions about:
1. Cams.
2. Porting & Polishing heads.
3. Header design.
4. Compression increase.
5. Gear ratios.
6. Clutches.
7. Suspension setups etc etc.
With reference to the above mentioned points (feel free to add if i have missed any) what are the things one must keep in mind while modding their cars. I shall try adding to the list as and when I can.
Old 26th August 2009, 22:48   #2
Vid6639's Avatar
Thanked: 19,593 Times
I would also suggest to give the drawbacks each one of these mods have on the car.
For example, header design. headers tuned for top end will completely kill the low down torque due to reduction in back pressure. headers built for street use will improve mid range but top end will not change much.
Old 27th August 2009, 00:24   #3
jkdas's Avatar
Thanked: 1,424 Times
Maybe a FFE? cat back? Details regarding this ? And 4x2x1 or 4x1 ?
Which Mattress To Buy and Points to Consider khan_sultan Shifting gears 421 7th January 2018 11:00
ARTICLE: Points to consider before TURBO-Charging your car Psycho On modifying a car 111 5th December 2014 20:04
My Naturally Aspirated Honda City VTEC sleeper - An evolving story! fieroid Modifications & Accessories 16 23rd March 2013 04:04
Reference Points - While driving and parking shibujp The Indian Car Scene 39 6th April 2009 10:09
Which of these would you consider while buying a new car?? karthik247 Shifting gears 9 5th May 2006 20:13
