Old 27th August 2009, 12:22   #1
Default Vista Tdi - Engine oil and the Check engine light turns ON
Hello Folks,
I just got a new Indica Vista Tdi last week. When I turn the key to the ON position the engine oil and the Check engine light turns on but refuse to go off. Once I start the car both the engine oil and Check engine light turn off. Is this normal. Also it would be great if somebody would help me get a Vista Tdi workshop manual
Thanks,
K,
P.S.
Mods,
Please correct me if I am wrong in posting the thread here.
skartik2 is offline   Reply With Quote
Old 27th August 2009, 12:30   #2
greenhorn's Avatar
Thanked: 1,516 Times
i think this is as expected, at least from my indica turbo. dont have the car with me atm, so cant check
Old 27th August 2009, 13:21   #3
Thanks Greenhorn, please let me know later.
K
Old 27th August 2009, 14:47   #4
teknophobia's Avatar
Thanked: 22 Times
This is perfectly normal.
teknophobia is offline   Reply With Quote
Old 27th August 2009, 14:50   #5
amitoj's Avatar
Thanked: 1,691 Times
Is this typical of diesels?
In my petrol car, the engine check light goes off after like 5 seconds. I crank the car only after that. The oil light stays on till i crank though.
amitoj is offline   Reply With Quote
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Oil check light flickering while engine is ON rajivanoj Technical Stuff 5 24th July 2011 01:01
Oil check light glows in 118NE, AFTER removing key adhiraj Technical Stuff 4 31st August 2010 21:39
