Old 1st September 2009, 11:11   #16
Jaggu's Avatar
Thanked: 8,683 Times
Usually clutch job involves, pressure plate, clutch plate and release bearing. Some will have carbon separate but nowadays it all comes as a single unit.
So yes the clutch job would have included the bearing.
Main thing being if you are opening, do a clean job and replace all parts. Dont do 2k savings now to land up with another 3k bill few months down the line, since these parts are not regular replacement/service ones.
Old 1st September 2009, 11:24   #17
Eddy's Avatar
Thanked: 5,068 Times
Hmmm.. sounds good.
But just one thing bothers me. There was no clutch slippage at all prior to this. 2000 rpm with AC = 85km/h since the beginning. But if competent says its worn out, I might replace it. I would have to trust them on this no ?
Eddy is offline   Reply With Quote
Old 1st September 2009, 12:49   #18
Jaggu's Avatar
Yup you need to trust them with this and can ask them to show the wear and tear to you
Old 1st September 2009, 15:20   #19
Eddy's Avatar
Getting the entire clutch assembly changed. Plus fixing of a leakage in the axle (now what is this ?)
Clutch+Pressure Plate: 3800
Labor: 1450
Leakage fixing: 300
Old 1st September 2009, 16:50   #20
Eddy's Avatar
Sorry for the bump mods, but need some inputs on the axle leakage please
Old 1st September 2009, 17:15   #21
SS-Traveller's Avatar
Thanked: 11,626 Times
Axle leakage is leakage of the gear oil from the gear box due to a failure of the oil seal at the end of the axles (drive shafts), which connect the gearbox to the wheels. No big issue.
Old 1st September 2009, 17:19   #22
Eddy's Avatar
Thats a relief. I hope its not a pointer to some bigger things to come !
Old 1st September 2009, 17:58   #23
Eddy's Avatar
Update:: The gear cable was defective too and needs to be replaced. Will get the car tomorrow !
Old 1st September 2009, 18:06   #24
Jaggu's Avatar
Any luck with warranty on any of the parts replaced?
Old 1st September 2009, 18:12   #25
Eddy's Avatar
The clutch bearing will be covered. The pressure plates and clutch plates won't be.
The gear cable is a grey area yet, will be known tomorrow morning. Gut feel is that it will not be covered.
Looking at 8-9k of expenses. This shakes the entire budget of the month ! :(
Eddy is offline   (1) Thanks Reply With Quote
Old 1st September 2009, 18:13   #26
humyum's Avatar
Thanked: 2,502 Times
Hey what about flywheel ? Changing that or no ?
And the gear linkages along with the shifter assembly ( comes together as one i guess ) is around 2 grand, someone has mentioned it in one of the threads and comes under warranty.
humyum is online now   Reply With Quote
Old 1st September 2009, 18:16   #27
Eddy's Avatar
Don't think they mentioned the flywheel.
Old 1st September 2009, 18:17   #28
humyum's Avatar
Oh, because if its unevenly worn out, u ll get clutch judders. Not a costly item u know!
Old 2nd September 2009, 13:01   #29
Eddy's Avatar
Update:
Just went to collect my car but noticed it juddered from pick up in the first gear. They acknowledged the problem and have kept the car back for a second round of observation.
What could this be ?
Flywheel ?
Old 2nd September 2009, 13:20   #30
... juddered from pick up in the first gear.
Flywheel ?
Flywheel imbalance or improperly fitted/worn out engine/gearbox mountings. May just involve changing one (or all) of the engine/g-b mountings.
Sound from the axle / front end of the car? Maruti workshops unable to solve brilliantlights Technical Stuff 26 5th December 2016 09:14
Linea Diesel: No one is able to solve engine problem EDIT: Now solved ! Travelbug Technical Stuff 35 21st November 2013 23:39
Problem: MPFI Esteem Engine Shudder turbo_c Technical Stuff 22 11th September 2011 21:41
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Clutch shudder in a new baleno Baleno155 Technical Stuff 0 6th October 2006 21:07
