Old 31st December 2011, 18:32   #46
Eddy's Avatar
Thanked: 5,065 Times
Default re: Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder
Updating this thread slipped of my mind. There was no shudder once I had driven some more. The clutch is going strong at 1,20,000 kms, touchwood
Eddy is offline   (1) Thanks Reply With Quote
Old 7th September 2013, 17:20   #47
Hi Eddy - Can you suggest reasonable priced and good quality MASS/Dealer in Gurgaon area ? or in Delhi ? Pasco in Gurgaon is asking 8K for clutch overhaul. Any comments/reviews ?
saurabhb2000 is offline   Reply With Quote
Old 7th September 2013, 18:26   #48
Eddy's Avatar
Hi Saurabh
Since the car is now out of warranty, I have stopped going to MASS.
However, I have heard that DD motors is ok. Do take competitive quotes before you make the final choice.
Eddy is offline   Reply With Quote
Old 8th September 2013, 23:03   #49
d3mon's Avatar
Thanked: 622 Times
I got my clutch changed recently (clutch cover + plate) and since then the gearshifts have become quite notchy, which were absolutely smooth earlier. I have to be really careful and slow with the shifts now.
Immediately after the change, it was really bad, and while it has become slightly better after about a 1000 kms, it's still far from perfect.
Any ideas on what could be wrong and what it would take to fix the issue?
d3mon is offline   Reply With Quote
Sound from the axle / front end of the car? Maruti workshops unable to solve brilliantlights Technical Stuff 26 5th December 2016 09:14
Linea Diesel: No one is able to solve engine problem EDIT: Now solved ! Travelbug Technical Stuff 35 21st November 2013 23:39
Problem: MPFI Esteem Engine Shudder turbo_c Technical Stuff 22 11th September 2011 21:41
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Clutch shudder in a new baleno Baleno155 Technical Stuff 0 6th October 2006 21:07
