Old 8th July 2005, 19:22   #16
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by Shan2nu
Problem with such engines is that the sudden surge of torque is so intense, you hardly gain anything from it. The car would spin it's wheels at the slightest hint of throttle.
Shan2nu
That's because he had a short first gear for the new found power. If the gear ratios were changed it would nt spin. That's typical with tuner cars....stuff is always mismatched.
Old 8th July 2005, 19:28   #17
Shan2nu's Avatar
Thanked: 89 Times
But that Skyline was a dream. It always had the right amount of power at the right time.
Shan2nu
Old 8th July 2005, 20:27   #18
Mpower's Avatar
Originally Posted by DRC
Thanks,
The intention is not to mod, but to understand technically what is responsible for Low end torque.
Thumb rule, What ever you want to do do it in ECU. But what?
Advance firing timing? Make the fuel richer? leaner?
Please prodon me If you feel I am really 1st grade boy in autos..
To get low end torque you need the following in the order of importance.
Forced Induction (either turbo or super charging)
More displacement (stroke rather than bore)
High compression
low lift and low duration cams (~)
long intake runners w/ smaller ID
long header tubes with enough backpressure
Ignition timing retarded (if unmapped)
AFR leaner than stoich
Rather than do all this, get yourself a Octavia TDI.
Old 15th July 2005, 14:17   #19
DRC
DRC's Avatar
Thanked: 48 Times
Thanks Mpower,
Is there a book or a site I can read about.. I am googling, In case you have a ready link..
DRC is offline   Reply With Quote
Old 10th July 2012, 16:50   #20
9thsphinx's Avatar
Thanked: 467 Times
Default Re: How to improve lower end torque..
This is probably the right thread to talk about how poor the low-end torque of the Honda Jazz is. I already have gained a slight bit on the low-end by installing a CAI, but it's still not enough. I am already contemplating a full SS FFE system. What I need is something that can make the car pick up faster at 2000-2500 rpms. My majority driving is in the city, and I care less how much time the car takes to reach triple digit speeds. What do you guys suggest needs to be done?
9thsphinx is offline   Reply With Quote
Increasing torque at lower rpms swathyd Modifications & Accessories 43 20th July 2009 15:25
Same issue - opposite effects on low end torque Jeep Technical Stuff 6 26th June 2008 13:38
Increase Low end torque in Swift Petrol pshyamsundar Modifications & Accessories 5 4th April 2007 12:30
Mod for low end torque in Swift talk2anand Technical Stuff 34 31st October 2006 10:20
giving the Swift some low end torque and fatter wheels theEnd Modifications & Accessories 14 21st November 2005 19:07
