Old 1st September 2009, 19:18   #1
Thanked: 282 Times
Default Ford Fiesta - Engine is off but some other motor is on
Yesterday I had one of the most strange experience with my Fiesta, after reaching home I removed the keys from my car, however there was some motor which was still spinning, it could not be the AC as the fan and AC were switched off.
I had a car parked in the front and hence I was not able to open and check which motor was it.
I restarted my engine and the noise stopped and I did not have the problem again.
Has anyone experienced this problem before... or any idea as to what motor could this be.
Chillout is offline   Reply With Quote
Old 1st September 2009, 20:49   #2
honda3938's Avatar
This could be a radiator fan . I think in some cars the fan runs automatically even if keys are removed and stops after cooling.
honda3938 is offline   Reply With Quote
Old 2nd September 2009, 14:52   #3
Thanked: 282 Times
Well even I hope it is the radiator fan, but this ran for more than a minute and that's what scared me. Hope I do not encounter this problem again else I may have to take it to the service center
Old 2nd September 2009, 16:08   #4
Thanked: 87 Times
It is the radiator fan.
The same thing happened in our Peugeot 307.No cause for worry.
Read in this forum that this happens for the Fiesta as well.
joy_swift is offline   Reply With Quote
Old 2nd September 2009, 16:13   #5
Thanked: 39 Times
Radiator fan, common occurrence with most new-gen cars. In fact in my car the fan keeps running sometimes for a few seconds (30-odd) after I shut down the engine. You should only be worried if it keeps running for more than a minute.
greenh0rn is offline   Reply With Quote
Old 2nd September 2009, 16:16   #6
tabrez02's Avatar
In my SX4 radiator fan gets off when i remove the key out. but it will keep running till the key is in at off position.
tabrez02 is offline   Reply With Quote
Old 2nd September 2009, 16:20   #7
honda3938's Avatar
i think it only happens in ford and fiat cars that radiator fan keeps on running even after remove the keys.
Old 2nd September 2009, 16:20   #8
Thanked: 24 Times
musicmanaman is offline   Reply With Quote
Old 2nd September 2009, 17:46   #9
karizma_devil's Avatar
Thanked: 16 Times
This nothing to worry its the radiator fan .. my fiat palio s10 fan runs for somethime even after I have removed the keys.
No worries.
karizma_devil is offline   Reply With Quote
Old 2nd September 2009, 19:00   #10
Thanked: 282 Times
Thanks a lot guys.... a big relief.
But I find it strange as to why they have this kind of mechanism, especially after removing the keys. I understand it helps to cool of the engine, but they should have built this in the ECM wherein an indicator should let us know the fan radiator is on. For example Fiesta beeps when you switch of the engine and leave your lights on. This is an helpful feature, but a more important feature like radiator fan should have been included. Hope they make this change in the next version
Old 2nd September 2009, 19:22   #11
FERRO's Avatar
one more thing to add also let the ECM decide how much time the fan should run to cool off the engine, depending on the battery condition otherwise it will kill weak/old batteries.
FERRO is offline   Reply With Quote
Old 2nd September 2009, 19:23   #12
pramod's Avatar
Thanked: 39 Times
Default Its a defect
I have a Fiesta and i have experienced this strange thing 6 to 7 times in the last 2 years of my ownership. As u say it is not an ideal behaviour as it doesnt seem to stop the fan even after a minute which is strange.
To bypass this, i switchon the engine again and then stop to overcome the issue.
Its a defect if u ask me.
Pramod
pramod is offline   Reply With Quote
Old 2nd September 2009, 19:41   #13
abhi1309's Avatar
Thanked: 25 Times
Happened with me to once or twice in the past 2.5 years of ownership. Bug for sure. Or some logic that is not understandable by end users. Switching on the engine again, fixed the otherwise unnecessarily rotating radiator cooling fan.
abhi1309 is offline   Reply With Quote
Old 3rd September 2009, 09:42   #14
JRD
JRD's Avatar
Thanked: 11 Times
It could be how its been programmed in the ECU. Did you guys have to push your car because the battery was drained due to this fan in 2 years of ownership? Answer is No correct?
It may sound odd that the fan restarts after a while but i think its normal. Other fiesta owners please confirm.
JRD is offline   Reply With Quote
Old 3rd September 2009, 11:45   #15
sgiitk's Avatar
Thanked: 3,885 Times
Radiator fan is not normally part of the ignition controlled circuits. Many cars even have warning stickers inside the bonnet to the effect that the fan may come an at any time.
sgiitk is online now   Reply With Quote
Ride the wind or party hard: My VW Vento and New Ford Fiesta take each other on! STARCHILD Test-Drives & Initial Ownership Reports 92 2nd November 2011 14:54
Alto : Engine Oil Light stays on. And some other issues abhibh Technical Stuff 33 18th September 2011 22:07
Ford Fiesta 1.6 SXI! I read…I went… I saw… I drove… but it conquered!!! JackTheCrack Test-Drives & Initial Ownership Reports 113 22nd May 2010 09:44
My new Fiesta TDCI and some other test drives dhiramos Test-Drives & Initial Ownership Reports 16 12th February 2008 15:30
Does the fuel pump run even when engine is off, but key in ON position ? supremeBaleno Technical Stuff 29 22nd January 2008 20:17
