Old 5th September 2009, 14:41   #16
Turbo Head's Avatar
Thanked: 83 Times
AFAIK If the blower switch is off, the AC and compressor also gets automatically off.
You may confirm this by the boost in the pickup of your car.
I never switch off the AC switch, it only blower speed/switch which does the job.
Turbo Head is offline   Reply With Quote
Old 6th September 2009, 19:30   #17
gpa
gpa's Avatar
Thanked: 282 Times
Originally Posted by aaggoswami View Post
This also prevents something called Icing. I dont know about latest systems, but in earlier systems icing was a problem.
This problem is not very common in the newer cars so long as the thermostat is working correctly ensuring that the compressor cut out happens at the set temperature level.
Old 6th September 2009, 20:04   #18
Thanked: 253 Times
When the blower switch is turned off the compressor also cuts off. There an interlock to ensure this.
It matters little which switch you turn the AC off with. But as Parm has said, keeping the blower running for a while helps prevent fungal growth and bad odours.
Old 6th September 2009, 20:41   #19
MileCruncher's Avatar
Thanked: 357 Times
Not always Anupji. In FIATs even if the blower is at 0 position with the A/C switch in on position, the blower still keeps running.
I would suggest rather than continuously switching on and off the A/C, control the temp in the car cabin through the thermostat that's been provided.
MileCruncher is offline   Reply With Quote
Old 6th September 2009, 21:39   #20
Yes, it was like this in my previous Fiat Uno.
janitha is offline   Reply With Quote
Old 6th September 2009, 22:28   #21
abhibh's Avatar
Thanked: 34 Times
Alot of Europeans cars are like this.
Old 28th June 2011, 15:23   #22
Thanked: 435 Times
Default Re: AC Switch OFF or Blower Switch OFF
Adjusting the thermostat nearer to the 'Red' portion results in heat being drawn from the engine coolant into the cabin. I guess this does NOT result in less use of compressor, so the petrol consumption would be the same as when the a/c is in full mode.
jinojohnt is offline   Reply With Quote
Old 28th June 2011, 17:25   #23
supertinu's Avatar
Thanked: 481 Times
I agree with Jinojohn. Heres my understanding or belief.
In cars with manual HVAC systems, the thermostat controls only the temperature of the air blown by mixing heat from car's coolant, it does not track the cabin temperature. So even if the temp is not set at the coldest, the compressor will continuously run and hot air will get mixed to increase the temp of the air, which is not exactly the most efficient way to do it.
In car with automatic climate control my understanding is that cabin temperature is tracked and compressor is shut down when desired temp is achieved.
My normal practice is to switch off the AC if it gets too cold but let the blower run to keep getting circulation, this should help efficiency as well vs changing the temperature setting. Also since i got a ford Ikon, i am anyways scared to touch the temp in the fear of the heater valve getting stuck
supertinu is offline   Reply With Quote
Old 28th June 2011, 18:08   #24
mmxylorider's Avatar
Thanked: 185 Times
^^^ That's correct.
Air conditioning (AC) essentially means changing the characteristics of ambient air to desired one. Cooling is of course the more commonly made change. In addition AC includes changing the humidity, pressure (used in data centers) etc
The advantage of running the AC with temperature controlled through the selector is the removal of moisture from the cabin which is most required in rainy season.
mmxylorider is offline   Reply With Quote
Old 29th June 2011, 12:02   #25
Thanked: 110 Times
Thermostat is provided to prevent Icing in the evaporator. For palio its set to 2.5 C grill temperature. The temperature knob is not a thermostat setting rather its a mixture control between Engine coolant and refrigerant to get desired temperature. So turning of the A/C will actually save fuel. For ACC setting the temp between 22~24C will save some fuel.
Vijay
vijaycool is offline   Reply With Quote
Engine switch-off procedure in cars rr_zen Technical Stuff 65 10th December 2009 21:55
Why blower smells after AC is switched off penpavan Technical Stuff 2 5th April 2008 23:00
Do you switch your system off before shutting the engine down? kb100 In-Car Entertainment 29 17th June 2006 14:55
switch off ur mobiles and computer today at 2225 speedsatya Gadgets, Computers & Software 10 4th November 2004 15:11
