Old 14th October 2009, 10:50   #61
Mushroomz's Avatar
Originally Posted by Travelbug View Post
There are two small amber lights just below the aircon controls and light from these two openings falls directly on the front cup holders.Although this light is dim but still might be useful in night.I think it's specific in ZXI variant.
I checked it today and did find the light. Its got a plastic cover it. How do i turn it on??
Mushroomz is offline   Reply With Quote
Old 14th October 2009, 11:17   #62
Travelbug's Avatar
Originally Posted by goandude View Post
You mean the amber lights from
- Air recirculation button
- Ac on off button
these are not meant for lighting anything only as an indicator
Didnt get the point you were trying to make
Hi Goandude,
The amber lights i'm talking about here are not from aircon controls. you have to stoop down and then you can find these lights on the base of the aircon panel. or just see 90 degree above your ashtray.. these small lights are parallel to car floor.
Hi Mushroomz,
These lights gets switch on automatically when you switch on your headlights but they are very dim, so to check keep your palm under them and then you can see them coming up.
Travelbug is offline   Reply With Quote
Old 14th October 2009, 11:25   #63
rr_zen's Avatar
Thanked: 268 Times
What is the purpose of these lights? If the illumination is dim as mentioned by Travelbug, does it really serve the purpose it is intended for? Also, is this feature specific only to the Dzire or does it find its place in the Swift hatch as well?
rr_zen is offline   Reply With Quote
Old 14th October 2009, 15:11   #64
sharma_sanjeevi's Avatar
Thanked: 89 Times
@Travelbug,
Are these lights specific to the ZXI / ZDI variants or they are available in VXI variant also ?
Was not able to check out the same as i am out of Mumbai, once i am back on 16th then only will be able to check, until that time i may get a reply from you
sharma_sanjeevi is offline   Reply With Quote
Old 15th October 2009, 09:58   #65
goandude's Avatar
Thanked: 455 Times
I asked this question on the auto lighting thread but no one seemed to know the answer. the question is "can the headlights of the swift / dzire be adjusted up and down?" No, not by the knob in the cabin marked 1234, but by a levelling screw, normally found on the rear of the HL assembly in older cars.
goandude is offline   Reply With Quote
Old 20th October 2009, 08:31   #66
Thanked: 89 Times
Originally Posted by sharma_sanjeevi View Post
@Travelbug,
Checked out for the Lights below the casing which is housing the A/C console, there were no lights, mine is a VXi variant.
I think it is specific to the ZXi variant, can anybody confirm this ?
Old 20th October 2009, 13:26   #67
maglev's Avatar
Thanked: 90 Times
1. The aircon controls the temp of air entering the cabin by letting hot, yes HOT, air mix with airconditioned air. I noticed this as i had adjusted the temp knob to the white 1/3rd form the blue ie approx at 9 o'clock position. here i swiched off the ac and viola hot air comes in. normally one would think that the ac compressor cuts in and out depending on temp setting. this is what happens in fridge and room ac. This mixing of hot air to control temp is highly wasteful and silly IMO.
2. We mostly have strolly type luggage and if you put one in the boot the luggage tends to shift around while taking taking sharp turns. the Dzire has some nice holes in the metal around the left and right of the boot (upperpart) where one can tie the luggage eliminating the shifting of luggage
The compressor cuts in only in cars equipped with climate control.
maglev is offline   Reply With Quote
Old 20th October 2009, 16:24   #68
Travelbug's Avatar
Default ZXI Specific
Hi Sanjeevi,
I have checked in my friends VXI and these lights were not there but they are there in my ZXI model So I guess these lights are variant specific.
TravelBug
Old 21st October 2009, 09:47   #69
goandude's Avatar
Thanked: 455 Times
In my Matiz with out any climate control the compressor cuts in and out. I could feel it, as the power loss, when compressor cuts in, is significant.
Old 19th August 2010, 20:06   #70
wrong! compressor cuts in all the cars.
opalcute is offline   Reply With Quote
Old 20th August 2010, 12:29   #71
Thanked: 89 Times
Has anyone noticed, that there are small Vents on the Dashboard of the Swift / Dzires near to the Steering Wheel. There are 3 Vents.
Can anyone tell, What are they for ?
Old 20th August 2010, 12:58   #72
nasa_hubble's Avatar
I think you are talking about the vents on the left side of steering wheel.
I think it is for the key reminder/light reminder chime.
nasa_hubble is offline   Reply With Quote
Old 20th August 2010, 15:29   #73
Thanked: 89 Times
Yes. I am talking about those vents.
Thanks for clarification. I will have a look at them, with the lights ON without the key in the Ignition Switch & Update.
Old 20th August 2010, 21:09   #74
buntydey's Avatar
As far as I remember, it is for some temperature sensor something. They say, never block those vents if you have the auto climate control.
buntydey is offline   Reply With Quote
Old 20th August 2010, 21:42   #75
sachinj12's Avatar
Thanked: 162 Times
You are right, it's for sensing the inside temp for A.C.C.
The low and mid variant just have the slots but now sensors.
sachinj12 is offline   Reply With Quote
Fiat Linea - "Did You Know?" Series VahanPujari The Indian Car Scene 443 1st November 2012 08:58
"I did not know this" show on National Geographic pjbiju Shifting gears 7 9th April 2008 15:15
Swift Dzire Petrol Vs. Swift Dzire Diesel reveal_da_zeal The Indian Car Scene 2 4th April 2008 21:52
Did you know? DCEite Shifting gears 21 15th January 2006 19:25
