Old 9th September 2009, 09:02   #1
Thanked: 45 Times
Default Air filter installation - help needed
I have changed the Air filter for my lancer diesel, as DIY method, but after installing, i have an doubt, whether any oil should be applied to the new filter or any other methods should be followed. If oil should be applied what oil should be applied. I am not sure whether oil should be used or not.
I have installed Stock replacement Sakura brand filter. Not performance filters .
rajivanoj is offline   Reply With Quote
Old 9th September 2009, 09:09   #2
jav
Was there oil on the old filter? AFAIK stock filters do not need any oil application.
jav is offline   Reply With Quote
Old 9th September 2009, 10:02   #3
Jaggu's Avatar
Thanked: 8,694 Times
Read the pack there will be instructions if oiling is required.
Old 9th September 2009, 10:05   #4
sgiitk's Avatar
Thanked: 3,884 Times
Oiling is normally required only in cleanable filters. Paper element filters (which are almost always disposable) do not require any oiling.
Old 9th September 2009, 14:48   #5
Thanked: 45 Times
@jav
I didnt see oil trace in old filter,
@jaggu
Theres no instruction on pack, but as most say, i shall use it without oil, since it is stock paper filter.
@sgiitk
Thank you sir, i have decided not to put oil. Till now, I thought we should put oil in all filters
Old 9th September 2009, 15:36   #6
rranjith_kum's Avatar
Thanked: 17 Times
Oil is used for Polyurethane foam and cotton gauze type air filters. Make sure yours isn't one !
rranjith_kum is offline   Reply With Quote
Old 9th September 2009, 16:04   #7
Sunilb's Avatar
Your filter does not require cleaning if its a paper element filter and hence no oil required.
Easily d[FONT='Calibri','sans-serif']istinguishable from a performance filter.[/FONT]
Sunilb is offline   Reply With Quote
Swift Cabin (AC) Filter Installation Sankar Modifications & Accessories 7 12th July 2016 15:58
Mitsubishi Cedia DIY - Cabin Air Filter Installation Captain Slow DIY - Do it yourself 1 27th May 2013 10:14
Air filter and Air intake sunilvarma Technical Stuff 10 4th November 2010 10:58
Best air filter or cold air intake for Skoda RS Kartik9500 Modifications & Accessories 9 7th February 2008 03:43
Question on K&N Filter installation for a Baleno sonic Modifications & Accessories 2 30th March 2005 11:50
