Old 17th May 2012, 20:43   #16
.anshuman's Avatar
Thanked: 9,159 Times
Default Re: Car Engine turned off abruptly
Originally Posted by usrivpx View Post
Hi Guys,
Today my indica got truned off suddenly at the red light . At that time the A/C of the car was also switched on and all of a sudden I noticed a spike in RPM meter and thereafter the needle came down to zero.
Please mention the engine and the model of the car, MPFI/IDI/IDI Turbo/DICOR??
Old 18th May 2012, 15:00   #17
Default Re: Inconsistent idling and engine shut off problem
Thanks for the quick response,
The engine is diesal, it is indica DLG 2005 model and the car has done 59,000 km. It is first time that I have seen such thing in my car.
The same thing happened today also twice with A/C switched on, the RPM that time spiked a bit little more at the red light and then the engine stopped . Next time when I noticed a little spike in the RPM meter, I quickly switched off the A/C, then engine didn't stopped.
Hope it helps. Let me know if any other information is needed.
Pradeep
usrivpx is offline   Reply With Quote
Old 18th May 2012, 22:37   #18
IndigoXLGrandDi's Avatar
Thanked: 161 Times
There is inconsistent idle rpm problem in our Indigo LS IDI (May 2004) which has covered 2,34,600kms. When the AC is turned Off, there is this inconsistent idle rpm problem. When the AC is turned On, there is no problem with idle rpm.
It feels like the someone is pumping the accelerator pedal (which is in fact not).
If I press the Accelerator Pedal slightly, the idle rpm becomes normal (the engine rpm increases though due to pressing of Acc. Pedal)
I have changed the Engine Oil (MAK Platinum 15W40 CI-4) & Oil Filter, Diesel Filter (Delphi) but still there is problem with the idle rpm.
Can someone please tell me where is the Idle Air Control Valve located and how to clean, adjust it? Is it a DIY Job?
IndigoXLGrandDi is offline   Reply With Quote
Engine Idling Problem KSM-Vtec Technical Stuff 53 29th May 2016 00:46
Yamaha Gladiator/SS125 - Inconsistent idling ron_9191 Motorbikes 17 3rd September 2014 15:13
Do all Turbos require idling before shut-off? GTO Technical Stuff 117 24th October 2012 20:10
Warming Up / Idling Engine before starting off... 911turbo Technical Stuff 29 23rd May 2009 13:02
Why can't we shut the heater off? santosh.s Technical Stuff 58 23rd March 2009 14:06
