Old 11th September 2009, 22:28   #1
Rai
Default Fiat Petra - Fuel Tank Cover
Hello All,
On my recent travel from Bangalore to Mangalore to Bangalore, I found that my average (Mileage) reduced drastically. I took the vehicle to Dealer and it was found that, the fuel Tank was Damaged (Thanks to Bangalore -Mangalore Road) and fuel was dripping slowly.
Dealer told me that, it will take time to order new Tank and hence only option is to 'Weld' the damages, for which I agreed.
I asked if there is any Under-Cover for Fuel Tank in Fiat Petra and he said NO.
Is this True? Fiat Petra doesn't have Fuel Tank Under-Cover? Is this true is other cars too?
Rai is offline   Reply With Quote
Old 12th September 2009, 11:37   #2
planet_rocker's Avatar
Thanked: 368 Times
You mean a fuel tank guard? like a sump guard? i guess you can get it custom made at any mechanic who prepares rally cars.
planet_rocker is offline   Reply With Quote
Old 12th September 2009, 17:34   #3
DRC
DRC's Avatar
Thanked: 48 Times
hmmm.... same road, same car, same problem!! Sorry to hear that.
I drove for 2 years with the leaking tank with m-seal stuck underneath. Finally got the tank changed for 5.5K.
Yes, the tank is very vulnerable. no gaurd nothing (i have not heard any car having it Gurus please confirm). The sheet metal is too thin and can not take welding either. May be we can fabricate a gaurd and fit.
Also, I heard some cars have PVC tank and are very difficult to fix.
DRC is offline   Reply With Quote
Old 12th September 2009, 21:21   #4
B.R.S.Rao's Avatar
Thanked: 56 Times
Mr. Rai, you are really fortunate to have only damaged fuel tank. Only tanks will survive on this Mangalore-Bangalore road.
What I suggest is that, remove the fuel tank carefully, weld it, apply anti-rust base paint, finally cover it with good enamel paint. You'll not have any problems for years. Ready made fuel tank guards are not available for petra. If you know any one who fabricates tin or aluminum sheets,(or vehicle body tinkers) ask them to fabricate guard for the fuel tank.( you can see fuel tank guards in Mahindra Bolero pick-ups)
Take care.
B.R.S.Rao is offline   Reply With Quote
Old 12th September 2009, 21:37   #5
vigsom's Avatar
Thanked: 604 Times
Please ENSURE you remove all petrol, purge the Tank with nitrogen or air before welding.
I'd have suggested steam/water wash but that will result in other issues post welding.
Again Please ensure an air/nitrogen purge before welding
Old 13th September 2009, 20:49   #6
Rai
Default Fuel Tank Guard
YES, when Dealer suggested me Welding, the first question I asked is regarding this only. Then they assured me that, they know the procedure and they are very well aware of the problems if they don't keep strict adherence to this procedure. In-fact, they are saying, now a days, atleast one or Two Vehicle per week they are getting with same Problem.
Customer will normally come with Mileage Problem itseems. and these folks check for Fuel Tank Damage or Fuel Pipe Damage as a first check itseems.
Last friday I got my problem fixed and now city average/Mileage is back to Normal. 9.5 KM to 10 KMS with 100% AC. I didn't do long drive after the fix. But I expect it to be normal, around 14.5 KMs with 100% AC. (Infact I didn't notice any mileage difference with AC ON or Off)
Fuel tank capacity measurement, how? giri Technical Stuff 79 26th June 2018 15:17
Can the fuel tank capacity be increased speedsatya Modifications & Accessories 4 11th November 2009 09:31
FIAT PETRA Power Steering problem and FIAT India's responsiveness! rishi_kapoor Long-Term Ownership Reviews 13 13th June 2009 09:09
Fiat Petra - Plastic Cover? Rai Technical Stuff 8 21st August 2008 18:59
fuel tank 42lt.- fuel in-44lt. v.tec Technical Stuff 55 29th August 2006 20:50
