Old 13th September 2009, 08:55   #1
drnibu's Avatar
Default fiat palio 1.9 d help needed
i use a 2005 palio1.9d elx.. She have clocked 67k kms successfully without a single hiccups.. recently i face a serious issue.. i need you peoples expert advise on it... "I crank the engine, she roars instantly, no issue, but on idling i see the rpm meter going up and down like there is some kind of knocking... If i start driving, in all gears i can feel the knocking... it jerks occassionally and the worst thing is, while cruising, on any gear if i take my foot off the clutch for more than say 5 seconds, the check engine light is shown and accelerator is suddenly dead like, it will respond only when i press it hard and suddenly stops responding at all.. engine is holding the idling, not going off, but no response from pedal.. And this complaint comes only once in a while, according to the service people, frm my experience, for every kilometer, i have to stop and restart... all service people from kerala, tvs, rf, concord could not find a solution for the same.. WHAT CAN IT BE????
drnibu is offline   Reply With Quote
Old 15th September 2009, 19:16   #2
aaggoswami's Avatar
Thanked: 1,541 Times
1) This thread should be in this section :
Technical Stuff - Team-BHP
2) Either something is wrong with fuel delivery, or ignition. Get your car completely checked by A.S.C. Cleaning injectors, etc. will be done, then further analysis will help IMHO>
aaggoswami is offline   Reply With Quote
Old 15th September 2009, 19:33   #3
Thanked: 42 Times
Fuel pump caliberation required I guess.The best way to understand that the fuel pump requires caliberation is when the fuel pump light(Red one) in the instrument cluster does not go off after a few seconds after turning on the ignition and you start the engine..the symptoms are the ones you mentioned in your post.
zen91 is offline   Reply With Quote
Old 16th September 2009, 10:53   #4
Thanked: 29 Times
It may require de-carbonisation of combustion chambers or cleaning of injectors. Did you ever do this before during your regular services ?
Seeler_Rebeiro is offline   Reply With Quote
Old 16th September 2009, 23:36   #5
drnibu's Avatar
I have given the car to tvs services in cochin, kerala for decarbonising and check up... will update you.. The fuel pump indicator is never shown after turning the ignition on..
Sorry about posting in wrong section, can i move the thread??
Old 3rd January 2011, 17:53   #6
Thanked: 149 Times
Default Re: fiat palio 1.9 d help needed
I am quite late in answering your query. I trust your problem is solved. In case you get such problem again, just get your EGR cleaned.
CANPUSH is offline   Reply With Quote
Old 4th January 2011, 23:25   #7
Thanked: 660 Times
get your fip calibrated at a reputed shop.
Old 19th February 2013, 12:56   #8
swami.n's Avatar
Thanked: 202 Times
Exclamation Re: fiat palio 1.9 d help needed
Re starting this thread as I'm facing a similar issue to what drnibu has mentioned. The Check engine light goes on in my 2004 Palio 1.9D once in a while while cruising 60-80kmph in 5th gear. Once I turn off the engine and restart, its gone, but again resurfaces when cruising. It doesnt happen when I'm driving in lower gears.
I got the scan done, cleared all errors in the scan, but its still occurs while cruising. Some mechanics say its just a problem with electricals and some say there may be problem with the Fuel Pump, but I dont understand why the fuel pump is having problem only in 5th gear. If I rev hard and go 70+ in 4th gear the problem doesn't occur.
I took the car to IGNITE on ECR, but they do only the palio petrol job and not the 1.9D and he said it may be a problem with the pump or electricals.
Can some of the gurus on this forum advice me on this or suggest me a Palio 1.9D specialist in chennai or outskirts.
swami.n is offline   Reply With Quote
Old 21st February 2013, 11:22   #9
swami.n's Avatar
Thanked: 202 Times
Question Re: fiat palio 1.9 d help needed
Come on guys. Are there no Palio 1.9 owners in Team-BHP.
Looking for some help
Old 21st February 2013, 11:34   #10
planet_rocker's Avatar
Thanked: 368 Times
What exactly happens when the injection failure light comes on? is there a loss of power? does the car show any signs of fuel starvation?
number of people with 1.9Ds on the forum has come down, i guess.
The owner manual doesn't give any concrete reason for it, but do check this out, atleast the last line.
there can be dirt in the fuel filter / water in diesel (is there any indication for the same?) any other signs of the car not running normally?
planet_rocker is online now   (1) Thanks Reply With Quote
Old 21st February 2013, 12:28   #11
swami.n's Avatar
Thanked: 202 Times
Thanks planet_rocker. There doesn't seem to be water in the fuel. Should get the fuel filter checked.
The car when cruising at 50+ speeds, I feel a mild fluctuation in the acceleration. ie its a bit oh up & down with no change in throttle. But the rpm meter does not go up & down. Its very mild.
This fluctuation doesn't happen in lower speeds.
Old 21st February 2013, 12:42   #12
Thanked: 368 Times
Originally Posted by swami.n View Post
Thanks planet_rocker. There doesn't seem to be water in the fuel. Should get the fuel filter checked...
you can get that checked. Modern diesel cars come with a Water in Diesel warning - so does the 1.9D
if you haven't yet replaced the Fuel Filter, please do so and see if the problem occurs again. It is hardly a 5 mins job.
Also DIY and open the air filter box and see the condition. it can even be bad fuel.
Old 21st February 2013, 12:59   #13
JayD's Avatar
Thanked: 2,008 Times
Good that Ignite did not accept your car for work!!
Please PM member Vijaycool on the forum. There is a mechanic by the name Murugan, just off OMR. He is pretty good with palios, and should be able to help yiou out.
Jayadev
JayD is offline   (1) Thanks Reply With Quote
Old 21st February 2013, 13:16   #14
Thanked: 368 Times
Oh yes! how did I forget please note down his contact details:
Work shop name : SMK Automobiles
> Owner Name: Murugan
> Contact : 9710992117
> 9710222117
planet_rocker is online now   (2) Thanks Reply With Quote
Old 23rd February 2013, 11:01   #15
Thanked: 149 Times
I once faced this problem in my Palio 1.9D (I no longer own it, sold three years ago and I regret now!) while traveling on highway. But soon as I refilled the tank it vanished. It was for quality of fuel. In case you are seeing the injection system light recurrently getting on while driving, please get the injectors cleaned. Dirt in injector sometimes blocks delivery of fuel, particularly in 4th and 5th gear when requirement is frugal and it is further reduced by the blockage. If the problem lies there and you get the injectors cleaned, you should also notice improvement is overall performance and fuel economy.
At the same time also get the EGR (Exhaust Gas Re-circulator) cleaned when you go to workshop.
CANPUSH is offline   (1) Thanks Reply With Quote
Advice needed on used Fiat Palio 1.6/Petra idofsuresh Hatchbacks 17 9th March 2015 19:44
FIAT Palio 1.6 GTX Fuel Pipe Needed - Urgent ravikn Shifting gears 16 23rd May 2008 18:31
Fiat Petra 1.6 ELXP or Palio 1.6 sports or Palio 1.2 nv ELX? Travel-X Hatchbacks 20 8th November 2006 18:36
Urgent help needed on Palio 1.2 Dhanan Hatchbacks 9 6th October 2006 11:58
