Closed Thread
Old 13th July 2005, 11:56   #1
Samurai's Avatar
Thanked: 14,315 Times
Unhappy Baleno levitation at 125+
This problem has been mentioned by me before, however no serious discussion has been done on this issue.
My Baleno is nearly 3 months old and has 195/60R14 Yokohama ES100 tyres on BSA 14x6J Alloys. I have noticed that it feels light as I start crossing 120KMs speed. At 130KMPH it literally glides on the road, therefore I haven't dared pushing it any further. Initially I thought it was the road, however it happened on other roads after that. So, I do believe I have a problem on hand. It sucks to have a Baleno with modded tyres and still limited to 120KMPH. Other day Rudra mentioned about feeling the same on a stock Baleno. However, V1p3r doesn't report any problem from his Baleno.
Last time when I discussed this with Iceman and Psycho, they both suspected the suspension. My next service day is nearing and I want some ideas on how to present my problem to Maruti service guys so that they will take real action. It will be quite difficult to demonstrate the problem (by driving at 130KMPH) in the middle of the city. Also I don't want to give them a reason to rip my car at that speed.
Does anyone else have the same problem with their Baleno? How do I explain this problem and what could be the possible solution I can suggest to them?
Samurai is offline
Old 13th July 2005, 12:19   #2
Rtech's Avatar
Thanked: 213 Times
It's really strange that you have this problem after fitting those tyres. Usually this sort of thing show's up with the stock tyres. i had a similar problem on my old astra, but new Falken's cleared that right up.
Its likely your larger tyres are tramlining too much. This happens with bigger tyres, and maybe the Yoko's are more susceptible to this than other tyres.
Rtech is offline
Old 13th July 2005, 12:39   #3
I do a 120 almost daily morning and a 130 once in a while depending on the traffic conditions.... haven't really experienced anything of this sort as such..
yes.. have never really experienced could also be a factor of not noticed.. will let you know in a couple of days tho'
btw.. mine went for its 2nd service last week.... and had its first tyre rotation... at around 5.5 k... is it normal or a lil early?
rgds
vivaid is offline
Old 13th July 2005, 12:50   #4
Thanked: 48 Times
@Samurai, if possible, drive another baleno at that speed. Lightness of steering can be very subjective and you might feel just the same when you drive V1p3r's car, even though he does not feel it. If I am not wrong, you are used to drive in US (more of D segment cars like Corolla?), which can be biasing your opinion as well. Just some thoughts!
RX135 is offline
Old 13th July 2005, 12:51   #5
Psycho's Avatar
Thanked: 95 Times
Hey Samurai... what is the current tyre pressure ???
Psycho is offline
Old 13th July 2005, 12:54   #6
turbo_lover's Avatar
i dont own a baleno but last year driving my friends ride i found while hitting high speed i found the nose to be very nervous ..so much so i had to bring the needle down while changing lanes...front end lift is present in the esteem aswell...
one thing i noticed about the A.S.S here with GM and Suzuki is that they cant seem to do much about such problems ..like the defects which come with a particular model....
front axle liftng could be purely lack of proper aerodynamic downforce and a soft setup..
turbo_lover is offline
Old 13th July 2005, 13:01   #7
Thanked: 48 Times
Hey, arent you the one who dragged your Alto with Adventure at 140+? So, what high speed are you talking off with Baleno? 160-170?
RX135 is offline
Old 13th July 2005, 13:04   #8
Samurai's Avatar
I haven't driven his car, but he felt the levitation when he was riding passenger with me in my car. So, it may not be subjective.
I used to drive Acura 3.2TL which was slightly bigger than Honda Accord. However, that was a sport sedan with V rated tyres, also it was much heavier and driven in US roads.
It is literally glued to the road at 80-100Kms, but that changes quite fast as I go higher. It can't be the tyres since Iceman had the same tyres in even thicker version.
Samurai is offline
Old 13th July 2005, 13:06   #9
Samurai's Avatar
It was 29 last time I checked.
Samurai is offline
Old 13th July 2005, 13:13   #10
Psycho's Avatar
Thanked: 95 Times
The tyre pressure is good... The float is typically wheny our front tyres start loosing weight on them usually blamed on aero dynamics.... an easy solution out of this is to see if the company can help raise the rear a lil bit. Also check if the front struts are soft...
Psycho is offline
Old 13th July 2005, 13:19   #11
drifter's Avatar
Thanked: 13 Times
marutis tend to float at higher speeds, but having driven a baleno...it didnt feel too bad at high speeds.
Drifter
drifter is online now
Old 13th July 2005, 13:20   #12
Rtech's Avatar
Thanked: 213 Times
Front end getting light at 160+ ok, but 120kmph is a really low speed. Don't know man...
Rtech is offline
Old 13th July 2005, 13:28   #13
speedsatya's Avatar
Thanked: 706 Times
if teh front struts are soft ,then the car shouldnt be lifting.it will bottom on slight dips .
i dont suggest raising teh rear,as thsi will change the handling considerably,your car will tend to oversteer.
tell someone else to drive your car at those speeds and se eif the problem really exists.
Write to maruti at www.marutiudyog.com.it works.
try reducing the tire pressure.
speedsatya is offline
Old 13th July 2005, 13:38   #14
i am talking speeds of 150k around that much .. it felt too light as if it was floating ...my friends OHC looked much happier zipping at that speed ..
EPS isnt much of a help either on the marutis is it ?? complete absence of power variability at high speeds ..
Old 13th July 2005, 13:40   #15
Psycho's Avatar
Thanked: 95 Times
Not necessarily depends on the the torque lift of the engine itself... if you notice when a car accelerates the nose of the car lifts... and yes it will bottom if the strut has gone completely soft ... however on a medium soft strut it will not bottom that easily
Yes it will over steer if the height is raised considerably, 1/4 to 1/2 an inch on the rear will not cause oversteer, the alignment will have to be redone. Have done it on quite a few car's including both my cars and there has never been an oversteering problem till date.
Psycho is offline
Closed Thread
Best 125 CC Bike krisme4u Motorbikes 27 28th February 2010 00:05
Delivery woes Suzuki Access 125 raghutk Motorbikes 7 11th March 2008 15:25
Need Help to modify my WIND 125 ultimate_rider Motorbikes 0 28th May 2006 01:24
125 cc shootout normally_crazy Motorbikes 12 11th October 2004 14:35
