Old 17th September 2009, 15:26   #16
Hi All,
Thanks for all the advice...
I will add 2T oil in petrol... but, I am still skeptical on adding 2T to petrol... But since you people have used and found it to be working.. i will also try it my car...
- I will get the spark plugs and injectors checked .
- I plan to install Phillips Rally H1 100W & H7 8W (with cutout)...
@Ravveendrra - May I contact you when I am in Hyderabad...
Originally Posted by Ravveendrra View Post
There are several workshops and mechanics in Hyderabad who do a good job on Fiats and Palios. I have not tried Solar but have heard several complaints about them,
Originally Posted by kri$hna View Post
I too agree with this method. It is a good trial and if your problem is set, then decarb again wud not be required, praneeth.
Originally Posted by FERRO View Post
+1.
one of the Injectors maybe faulty. better get it checked before other.
npraneethreddy is offline   Reply With Quote
Old 17th September 2009, 15:39   #17
Hi Ravveendrra,
How will adding 2T oil to petrol help?
I am trying to find any threads that could help me out here but I am not able to find any.
Thanks in advance
TracerBullet is offline   Reply With Quote
Old 17th September 2009, 18:23   #18
Ravveendrra's Avatar
Thanked: 406 Times
Originally Posted by npraneethreddy View Post
Hi All,
You are welcome to contact me anytime.
Originally Posted by TracerBullet View Post
Hi Ravveendrra,
Thanks in advance
Here is the link to the thread with a whole lot of information, gyan, debate etc. : http://www.team-bhp.com/forum/techni...-oil-fuel.html (My Experience Of Adding 2T Oil In Fuel)
You may also read my opening post http://www.team-bhp.com/forum/test-d...ml#post1271071 in my thread: http://www.team-bhp.com/forum/test-d...-2nd-hand.html
Let me add here that I have been giving my cars 2T oil treatment once in a while since 1990 or thereabouts, I have always noticed the improvement and have not noticed any damage or harm.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 18th September 2009, 09:18   #19
Thanks Ravveendrra. I will try this with my car too.
Old 18th September 2009, 12:20   #20
Hello All,
I am planing to change engine oil from Mineral to Synthetic. Please adivce me on which brand and grade is suitable for my Palio 1.2.
Old 18th September 2009, 16:13   #21
Thanked: 29 Times
Hello All,
I have a Perol 1.6 - try "Shell Helix Ultra 5W-40 Fully Synthetic"
Seeler_Rebeiro is offline   Reply With Quote
Old 18th September 2009, 17:10   #22
neoonwheels's Avatar
Thanked: 630 Times
You can also check out Selenia 5W-40 K. Its FIAT recommended synthetic oil. I have put this in my car and have driven 1.5K after that. The engine has become smooth and rev happy. Mileage is marginally improved.
neoonwheels is offline   Reply With Quote
Old 18th September 2009, 17:14   #23
One more question
- Now my engine is on 100% mineral oil, do i need to do Engine flush before Adding Synthetic oil or is it not required at all.
How would this cost me.
Old 19th September 2009, 13:37   #24
Thanked: 29 Times
One more question
A flush is recommended. Depends on your service cente, usually one unit of flush + labour should cost around Rs 440 in Mumbai. Go for Selenia, since it is recommended by FIAT and used on their other cars.
And yes, you will also need to change the oil filter.
Old 21st September 2009, 13:07   #25
Hello,
I have installed new Phillips H1 100W & H7 80W in my Palio.
from the first use I find there is a improvement in the lighting. Will again check it when i travel to Hyderabad.
One question, Will this high power bulbs drain the battery.
Old 22nd September 2009, 10:56   #26
Thanked: 630 Times
One more question
No flushing is required if the original engine oil does not contain any metal particals or dust when you get it out. Selenia 5W-40 K (Petrol) oil costs 610/- per liter. It takes 3 liters for a 1.2 Palio.
Old 22nd September 2009, 17:07   #27
Hello All,
For the last couple of days i have been observing that, car is pulling to left side and I get a feeling like traveling on a Boat. What could be the Problem. I have checked the Air pressure and recently done the Alignment and balancing of Wheels.
Old 22nd September 2009, 17:21   #28
vrprabhu's Avatar
Thanked: 370 Times
I had my car (1.2 NV ELX) serviced yesterday - I used Castrol Magnatech. I had a new can opened, and there was less than 1/2 litre left over after topping up. I was told it takes in about 3.6 litres to fill completely - checked the oil level through dip stick, and I showed full.
BTW, where do you get your car serviced?
vrprabhu is offline   Reply With Quote
Old 22nd September 2009, 17:28   #29
Thanked: 33 Times
My car had the same problem, used to give an explosive sound , only difference is that you get it on idle whilst i got it in my car high up in the rpm meter.Now, i used to get regular service done, which included periodic oil , filter(s), sparks plugs replaced .., etc. My car's engine was flushed and i had it de-carbonized . Yet, at high power band, there used to be an explosion followed up with knocking.Finally, with the assistance of our preferred mechanic , we identified that the problem was the ignition coil which was causing a misfire at one of the cyclinders!. I got the ignition coil replaced , and since then there has been no misfires.
ritedhawan is offline   Reply With Quote
Old 23rd September 2009, 10:42   #30
Thanked: 630 Times
Since last couple of years I am getting it serviced at BU bhandari wakad. For my car it took, 3 liters of engine oil. I changed to Selenia as FIAT uses the same oil in Linea and Punto.
Fiat Palio ELX fuel efficiency issues csshyamsundar Technical Stuff 44 30th May 2012 11:03
Idling issues in my Fiat Palio Radnam Technical Stuff 25 25th April 2012 09:25
Fiat Palio Stile 1.1 Throttle Potentiometer Sensor Issues mojorising Technical Stuff 9 9th March 2010 14:46
Fiat Palio 1.2 Starting Issues amitverma Technical Stuff 11 25th December 2009 10:37
