Old 25th April 2011, 18:25   #46
star_aqua's Avatar
Thanked: 89 Times
Default Re: FIAT Palio 1.2 - Issues
Originally Posted by motionfreak View Post
Guys please help.
I need the car for a long drive in the next month
Any mechanic can change the axle aka drive shaft. but if you experiencing the kat kat only at full lock, then you can use the existing drive shafts till you get the kat kat noise while driving in straight line. but while turning don't power up the car. try to sail while taking turns or just use clutch while taking turns. it will extend the drive shaft life.
star_aqua is offline   Reply With Quote
Old 25th April 2011, 22:54   #47
gemithomas's Avatar
Thanked: 138 Times
He must be referring to the lower arms. The symptom for a problematic lower arm is a pronounced tak tak sound when the car moves with a fully turned steering. I think it should cost you something around 3.5K each.
Old 27th April 2011, 19:06   #48
motionfreak's Avatar
Thanked: 54 Times
Thanks guys. so i'll postpone the surgery
motionfreak is offline   Reply With Quote
Old 14th July 2011, 12:42   #49
Hello,
I need to get the Wring Checked in my Palio 1.2, Please help me the the contact details of a good mechanic in Hyderabad.
Thanks in advance
npr
npraneethreddy is offline   Reply With Quote
Old 31st August 2011, 19:15   #50
Ripper's Avatar
Thanked: 21 Times
Palio Question
I bought a pre owned Palio 1.2 a few months back. I want to know the spark plug specs, as i plan to change them at the next service.
The manual says Champion RC8BYC for the 1.2 and NGK BKR5EZ or Champion RC10YCC for the 1.6.
I prefer NGK over champion, i need you valuable suggestions on which one to go for. Thanks!
Ripper is offline   Reply With Quote
Old 31st August 2011, 21:52   #51
Thanked: 21 Times
Hi Ripper .. i noticed that you're in Mumbai. Which service station do you use for your Palio and are you satisfied with their service ?
Thanks in advance for the info. Cheers
revvhed is offline   Reply With Quote
Old 1st September 2011, 02:17   #52
Ripper's Avatar
Thanked: 21 Times
@revvhead: I take my car to a local mech (in malad). I just get the oil , filters, brake pads etc changed from him. for anything else i visit Nakita motors in Bandra.
Old 2nd September 2011, 09:41   #53
sanjaymugur's Avatar
Thanked: 53 Times
Originally Posted by Ripper View Post
Palio Question
champion copper plugs are far better than NGK copper plugs, champion plugs have more pickup & dissipate heat faster & hence engine is cooler, NGK's have an edge in PLATINUM,IRIDUM plugs....
stick with RC8BYC or go for NGK equivalent BKR6EKC
sanjaymugur is online now   (2) Thanks Reply With Quote
Old 2nd September 2011, 17:08   #54
junkishya's Avatar
Thanked: 45 Times
Originally Posted by npraneethreddy View Post
Hello,
Thanks in advance
npr
You can goto New Mars in Moosapet. Mr Prabhu, the owner, can help you out. You can also try Concord but they will check the wirng seriously only if there's any existing problem with the wiring.
What kind of issues are you facing with your wiring ? Mutiple issues like indicators not working + wipers not working + headlights could be related to a single part i.e. Combination switch.
junkishya is offline   Reply With Quote
Old 24th July 2012, 12:41   #55
Hi Guys,
Have a 2005 model 1.2 sport. now at 80K km. its been a dream car and love it nuts!! so much that my wife prefers to drive this rather than the i20 - as this listens to your wishes and handles like a dream!! well more on the 80K km love affair in the next post
Just moved to Bangalore, in search of a good service centre to get a thorough overhaul of the car - Gears, Clutch, Suspension, Engine
regards
ajayalex is offline   Reply With Quote
Old 24th July 2012, 15:18   #56
Thanked: 53 Times
Originally Posted by ajayalex View Post
Hi Guys,
regards
Mahadev at SV Cartech at TC Palya near Koshy's Hospital is the place you go to for all FIAT related cars... he is trusted & does the JOB well & has know FIAT cars since Sundaram times.... contact Mahadev @9 6 6 3 3 6 5 7 2 4
another alternative is KHT motors, a FIAT A.S.S...
another piece of advice... never go to Venkatesh of GOWRI automobiles... he is a BIG CHEAT... BIG TIME....
sanjaymugur is online now   (1) Thanks Reply With Quote
Old 24th July 2012, 18:18   #57
bejoy's Avatar
Thanked: 437 Times
Hi Guys,
regards
There are many dependable service centers in Bangalore - both Tata/Fiat as well as independent. Depends on which one you prefer and which one is closer to you. I live in South Bangalore and had been getting good service from Green Tracks in their glory days. Now, I prefer Prerana(Tata/Fiat) on Kudlu gate, Hosur road. The Concorde(Tata/Fiat) next door is equally good (from feedback). Never experienced KHT or CarTech, but both have good feedback from owners. Concorde on Mysore road also seems to be good. Mixed feedback from Gowri and some bad ones lately.
bejoy is online now   Reply With Quote
Old 24th July 2012, 18:22   #58
Thnx BeJoy,
I live in Vasanth Nagar - anything close by would help. But if the guy is good, don't mind the extra travel
Old 11th September 2012, 13:34   #59
Thanked: 95 Times
I think his name is Madhav. I strongly recommend SV Cartech. They are very knowledgable, honest and hardworking. They do not take short cuts and tell you upfront what can be done and what cannot. Their charges are very competitive.
zoombiee is offline   (1) Thanks Reply With Quote
Old 12th September 2012, 12:32   #60
Thanked: 28 Times
Default Re: FIAT Palio 1.2 - Issues-critical
Hi bhpians,
I have a 2002 Palio Elx, done 28K kms. An effort for some TLC has turned around to an extent.
The car performance had dropped marginally after the service, essentially a wash. Yes, the ECU & ignition coils were religiously covered, since the service station person had burned his fingers once. Yet there is an ounce of performance drop I am experiencing.
Got the AC serviced since the cooling was low. There is a considerable performance & FE drop when the AC is switched on. The cooling has not improved much, which I am getting it checked by the AC person.
Feel the car was better without the servicing.
Also can someone help with a mechanic who 'knows' FIATs in South Mumbai.
Kavesh
kavesh55 is offline   Reply With Quote
Fiat Palio ELX fuel efficiency issues csshyamsundar Technical Stuff 44 30th May 2012 11:03
Idling issues in my Fiat Palio Radnam Technical Stuff 25 25th April 2012 09:25
Fiat Palio Stile 1.1 Throttle Potentiometer Sensor Issues mojorising Technical Stuff 9 9th March 2010 14:46
Fiat Palio 1.2 Starting Issues amitverma Technical Stuff 11 25th December 2009 10:37
