Thread Tools
Old 14th July 2005, 11:12   #1 (permalink)
Default Swift reverse gear sound
Whenever i switch to reverse gear a very sharp sound is heard.This dosent occur every time,but most of the times.I am not able to figure out this.
On enquiring from service center they told me that ther is design constraint in Swift,and you shouldn't change gear immediately after starting the engine.Switch to reverse gear only after 30 seconds of engine start.I dont know how truth it is.Will tell u more after confirming this.
Also what can be the relation between engine idiling and gear changing.
abhi1881 is offline   Reply With Quote
Old 14th July 2005, 11:23   #2 (permalink)
speedsatya's Avatar
is it a grating sound.
if its this sound then it happens if the gears ar enot engaged properly.
change to neutral and remove your foot off the clutch .now again shift to reverse,this sound shouldgo.
used to happen in my car when it was brand new.
speedsatya is offline   Reply With Quote
Old 14th July 2005, 11:41   #3 (permalink)
Xsailor's Avatar
Default What they say is True
Hey Abhi,
I am not a Auto techie, but if what I have read is correct, the chaps @ Maruti are right! The fwd gears are Synchromesh and the Reverse is a sliding gear why they recommend the procedure of 30 secs. I am not very sure but have read this lately somewhere (perhaps on the forum itself - please checkup).
BTW, my Swift does this too, once in a while specially when it has been parked for a long time on my factory parking and the initial gear that I engage is the Reverse.
__________________
Lt.Col.Frank Slade: You're in no position disagree with me, boy. I got a loaded .45 here. You got pimples.
Xsailor is offline   Reply With Quote
Old 14th July 2005, 11:42   #4 (permalink)
Surprise's Avatar
Rightly said. I was facing similar problem while attempting to take reverse in my Swift. While discussing with my friend, I explained him about the strange sound and he did said the same.
He took the wheels and did this for many times to prove that noise is due to not engaging the gears properly. After that I have not faced any problem
Surprise is offline   Reply With Quote
Old 14th July 2005, 11:46   #5 (permalink)
What is gear engaging?Which one is proper?
Old 14th July 2005, 12:20   #6 (permalink)
Question
Surprise,He took the wheels and did this for many times to prove that noise is due to not engaging the gears properly.
How do you do this?I mean what have you done?
Old 14th July 2005, 13:29   #7 (permalink)
speedsatya's Avatar
read what i have written.it should help.
Old 14th July 2005, 13:53   #8 (permalink)
Lets go step by step ,lets asssume my car is stationary and engine is off.At this point car is in neutral
1. I start the engine, wait for 30 seconds.
2. Now if i change the gear to reverse, i get the sound(Most of the times).
Even if after this i change to neutral and reverse,and if no sound is produced what will be the use of it.
What can be done to prevent this at first place itself?
Thanks fo showing the concern.
Old 14th July 2005, 14:06   #9 (permalink)
Shan2nu's Avatar
Try this for a change.
Start your car,
shift it into 1st,
bring it back to neutral,
leave the clutch,
press it again and then shift into reverse.
This should make a diff.
I always double clutch when i shift into reverse (especially when the gearbox isn't warmed up).
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 14th July 2005, 14:26   #10 (permalink)
speedsatya's Avatar
yeah what i said is same as what shan is saying.
Old 14th July 2005, 14:36   #11 (permalink)
merve_extreme's Avatar
In the Palio 1.6 they have said wait for 2 secs after declutching before shifting into reverse.try doing something similar.
__________________
No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz
merve_extreme is offline   Reply With Quote
Old 14th July 2005, 16:11   #12 (permalink)
Thanks all for the information,i will definitely try this and revert.
Old 15th July 2005, 10:00   #13 (permalink)
Unhappy
Shan2nu Try this for a change.
Start your car,
shift it into 1st,
leave the clutch,
Even this dosen't help.Worked for first time(yesterday) but today morning same sound is produced even after following above steps.
Man this is killing me.I think i have to go to Service Station.
Also does any body knows whether this sound affects gear also is this happens only in new car?
Thanks and Regards
Old 15th July 2005, 19:58   #14 (permalink)
Team-BHP Moderator
Mpower's Avatar
First question
Any of the Esteem people experiencing the same issue.
If not, looks like Maruti took out the syncromesh to save money on the Swift.
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 15th July 2005, 20:52   #15 (permalink)
Shan2nu's Avatar
Most cars in India don't have a syncromesh on the reverse gear. But, neither does the "Vtec" nor the "Wagon R" have such a problem.
It's common, that reverse is sometimes hard to get into (early in the morn) but i've never heard any noise comming from it.
Unless we hear the sound, it's impossible to help you out.
Get the car checked asap.
Shan2nu
__________________
Thread Tools
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 17:31
Fiat Palio's Reverse Gear Clip Broken! rOaD AsSaSin!! Technical Stuff 27 27th December 2007 13:41
Skoda Oct. 1.9 Tdi: Vibrates during takeoff and in the reverse gear abhargava75 Technical Stuff 11 11th June 2007 01:32
Tachometer vs Engine sound. What do you prefer more while gear shifting? salilpawar1 The Indian Car Scene!! 74 25th April 2007 15:40
Reverse Gear ramkya1 Technical Stuff 23 12th January 2006 22:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
