Old 16th July 2005, 22:20   #16
v1p3r's Avatar
Thanked: 26 Times
Hey super, taking a year off from engg to do this, among other things.
Google "locost", and you should get some interesting info off the web.
I know exactly how you feel about engg man, there are no words (acceptable on this forum!) to describe it!
Old 17th July 2005, 10:20   #17
dude i would suggest you use a dolphin chassis... will you find one dirt cheap... you are based in banglore so finding a used one should not be much of a problem.
sanket12 is offline   Reply With Quote
Old 17th July 2005, 14:17   #18
v1p3r's Avatar
Thanked: 26 Times
Is the Dolphin FWD or RWD?
Old 17th July 2005, 23:30   #19
Psycho's Avatar
Thanked: 95 Times
Originally Posted by superunknown
what i dont understand abt transversely rear mounting an engine is how tranny setup will work...would the actual gear stick be close enuf to tyhe driver because the steering column obviously cant be elongated safely so positioning the the drivers seat further back would be out of the question...
Well "Jugad" is the word... cables can be used as an alternative a lil tricky but can be done... as rtech said choose the type of car and then choose the platform. the dolphin is a rwd but is useless for a rear mounted setup... and trust me it is not easy as you will have to change the entire drive train of the dolphin. I would rather suggest the herald chassis for your kinda needs if you want a front mounted setup. So one word "Plan"
Old 17th July 2005, 23:34   #20
v1p3r's Avatar
Thanked: 26 Times
Is it possible to construct a tubular steel spaceframe chassis, and adopt the drivetrain of a front-engined RWD vehicle? Isn't that what most kit car makers do, or am I sounding stupid?
Old 17th July 2005, 23:46   #21
Psycho's Avatar
Thanked: 95 Times
not as easy as it seems ... it takes years to get the chassis to handle right any warp on the chassis and you will have a non hamdler... easier to go with an existing chassis and build on. else you always have the option to buy yourself a old formula india chassis...
Old 19th July 2005, 11:33   #22
Old 19th July 2005, 12:47   #23
turbo_lover's Avatar
does anybody remember the Standard Gazelle ? wouldnt that make a kick@$$ car to build on ..its a RWD small that the Fiat 1100's wider than the Omni ...decent engine space too ..
turbo_lover is offline   Reply With Quote
Old 19th July 2005, 20:20   #24
v1p3r's Avatar
Thanked: 26 Times
:WTF: Aren't the Herald and the Gazelle the same?
Front Wheel Drive v/s Rear Wheel Drive Revvhead Technical Stuff 269 3rd August 2017 15:48
From a 4 Wheel drive to a rear wheel drive. My Contessa kittigadu Test-Drives & Initial Ownership Reports 16 7th November 2011 14:28
How do front wheel drives and Rear wheel drives behave in a skid adrian Technical Stuff 10 29th June 2011 17:51
Front wheel drive Vs Rear wheel drive ivar1951 The Indian Car Scene 2 17th March 2010 15:08
Rear wheel drive or Front wheel drive : What is your choice ? adrian Technical Stuff 1 25th January 2010 16:26
