Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 20th September 2009, 11:58   #1 (permalink)
Unhappy Grinding noise coming from the front brakes of Swift Vxi when rolling back
I recently bought a swift Vxi which has done 4000 kms. I noticed a grinding noise coming from the front brakes when rolling back slowly on an incline from standstill. This happens only when rolling back when I press the brakes slowly. Can anyone tell me is this is normal?
vivekchugh is offline   Reply With Quote
Old 20th September 2009, 18:16   #2 (permalink)
gpa
gpa's Avatar
What you are experiencing is normal. This usually happens when the brakes are cold or after you have driven through water or washed the car.
__________________
Maruti Suzuki Alto (May 08) - 23,000 KMS
Hyundai Santro (Feb 05) - 59,000 KMS
Old 21st September 2009, 20:13   #3 (permalink)
mithun's Avatar
Recently changed the disc pads ?
OR
Did the A.S.S opened the brakes ?
If this happens only when in reverse, it's not normal.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 21st September 2009, 20:24   #4 (permalink)
SS-Traveller's Avatar
That's a non-issue. A grinding/grating sort of noise is expected when the discs/drums rub against the pads/shoes in the wrong direction (reverse), because they are not bedded in for full grip in that direction. Even a little moisture on the pads/shoes can produce that kind of noise.
If you don't get any noise while braking during forward movement, don't bother.
__________________
“Medicine, the only profession that labors incessantly to destroy the reason for its existence” ~ James Bryce
Old 21st September 2009, 22:38   #5 (permalink)
mithun's Avatar
I admit that the grinding/grating sort of noise arises when the discs/drums rub against the pads/shoes. But the noise would be there irrespective of the direction !
Then, Why this happens only during reverse ?
__________________
Old 21st September 2009, 22:50   #6 (permalink)
MutantX's Avatar
This happens on my i10 also. It is a common problem. When you take reverse in an inclined slope you get a "tak tak tak" sound. I have got the same sound. I would suggest, you compress your cluth completely when you take reverse. The problem is, when you take reverse in a slope, without the cluth being depressed, the back breaks come into effect countering the movement. Hence, I suggest you press your clutch completely when taking reverse in a slope. I tried it and I do not get the noise anymore.
__________________
Engine is an extension of the human heart
MutantX is online now   Reply With Quote
Old 21st September 2009, 23:01   #7 (permalink)
Because the pad/shoe material, which sometimes has fine metallic fibres embedded in it, beds in, in the direction of use - forwards. When braking in reverse, the grip is not even, so the disc/drum stops in a jerky fashion, generating the noise. Can also sometimes happen going forwards - not as frequently though!
Q: Sometimes my brakes make a grinding or groaning noise that only happens at very low speed stops. Are my brakes going bad?
A: Only a complete brake system inspection by a competent brake specialist can give you the truth, however the particular noise you are describing is generally considered normal, particularly on vehicles with semi-metallic pads or most front wheel drive cars. The noise is simply a vibration that can be more felt than heard coming from the front disc pads because on slower stops you don't have the brakes applied fully which allows them to vibrate against the rotor surface. Usually no service is required as the noise is unavoidable, however if the noise is constant and occurs at almost every stop, the brake system should get immediate service.
Quoted from: Just Brakes - Frequently Asked Questions on Brake Repair
__________________
Thread Tools
Strange Noise from LHS front suspension Swift viana Technical Stuff 19 31st August 2009 12:55
Loud grinding noise from the rear reignofchaos Technical Stuff 19 26th March 2009 17:14
Disc Brakes for Swift Back wheel pshyamsundar Modifications & Accessories 39 3rd February 2009 13:32
Grinding noise in gear-change! ramzsys Technical Stuff 3 1st October 2007 23:37
Baleno: Rolling noise what is the truth? javedbhaimumbai The Indian Car Scene 25 21st October 2005 04:44
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
