Old 21st September 2009, 13:48   #1
Default OPEL Sail starting problem
hai friends
I drive a OPEL Sail 1.6, two days back on a long drive thebattery charging alternator failed as noted in the dashboard, switched of the A/c & drove to reach the next nearest place. The voltage dropped after a while & all went blank -the car stopped after stalling.
The battery voltage was 10.5V guessed the fuel p/p must have dropped pressure, also the engine did not crank. Managed to geta new replacement & fitted it. But the engine fails to start. Checked the petrol supply Ok till the fuel manifold, cleaned & checked all spark plugs were good.
Any ideas on what might be wrong? Please inform any good service persons in Chennai other than the dealer. Also look forward for your suggestions.
Thank u all
M.Srinivasan
98412 77536
mscheenu is offline   Reply With Quote
Old 21st September 2009, 14:51   #2
ElantraGT's Avatar
Srinivasan,
Are you getting a crank on your engine when you try to start or is it absolutely silent (after the alternator). The car needs atleast 12.24V from the battery to start. How much voltage are you getting on your battery now? If the battery is down you should hear a click sound when you crank your engine.
ElantraGT is offline   Reply With Quote
Opel Corsa Sail 1.4 2004 model ignition problem ranabirghosh Technical Stuff 14 12th December 2011 21:21
Opel Corsa Sail 1.4 Engine heating problem. Please Help! stevie Technical Stuff 15 20th January 2010 00:59
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
opel corsa sail 20,000 kms report dadudeonfire Long-Term Ownership Reviews 12 26th December 2005 21:19
Opel Sail 1.6 shamishchandras The Indian Car Scene 6 8th June 2004 13:27
