Old 16th December 2013, 13:00   #76
schakravarthy's Avatar
Thanked: 3,967 Times
Originally Posted by avira_tk View Post
I doubt this alloy can be repaired, if you are getting new tyres, 16inch tyres are quite common in that size, the Verna has that size and it needs new shoes often, Yoko is one option. A bent alloy is bad news, basically it life is over if you can't get it balanced, from the details in your post I think its beyond repair.
16 inchers are common, yes, but the widely available tyre is 205-55, not 50. I doubt if 205-55 can be fitted to my car.
Its sad about the alloy though. :(
schakravarthy is offline   Reply With Quote
Old 16th December 2013, 13:29   #77
Cyrus_the_virus's Avatar
Thanked: 156 Times
Default Re: Strange ABS behaviour in Fiat Punto
Interesting. Why?
Originally Posted by VeyronSuperSprt View Post
This is wrong information. ABS works on drum brakes too and cars come with 4 wheel ABS even when they have drum brakes on the rear.
ABS works on all four wheels even if the rear wheels are equipped with drum brakes.
There is a wheel speed sensor attached that gives feedback to the main controller which then works out the ABS.
My Bad, thank you. I haven't looked up ABS since I first learnt about it several years ago which had all pictures of discs as illustration.
However, I would still think that ABS would not be half as effective with drums due to amount of mechanical action in engaging and disengaging the brake shoes. The quick pulsating effect of holding and letting go of the disk several times in a second, I can't imagine how slow that would be on a drum.
Cyrus_the_virus is offline   Reply With Quote
Old 19th December 2013, 10:43   #78
I got this reply to my query on another forum. Can this be the problem?
"Just Wondering if ABS is wrongly activated at low speed as well. Await expert opinions, however, this link is an interesting read.
http://www.picoauto.com/tutorials/diagnosing-abs.html
Old 25th January 2014, 12:58   #79
I have changed the alloy wheels to OEs and have bought new tyres but still the problem persists. The SA at FASS inspected the front disc and claimed that since that since there is a 'groove' formation on the plate, the abs is functioning incorrectly. Is this a possible explanation?
Old 26th January 2014, 22:46   #80
pzkfg6's Avatar
If there is a small bend in the brake disk the ubnormalty will be transmitted to the calipers to feet during normal breaking. Check for bend, if it is minor, they skim a layer make it clear and the problem will solve or may be made not very prominent. If bend, better replace.
Vibration due to disk bend will be directly related to the speed at which the wheel revolves. You can identity it easily.
It's very fast with ABS and diminishes when the wheel gets traction.
I hope this helps . . .
pzkfg6 is offline   Reply With Quote
Old 27th January 2014, 18:02   #81
Afaik, there's no bend in the disc. Just the regular 'step pattern' that appears as the plate wears out due to friction between disc pad and plate.
Fiat launches pre-facelift Punto as 'Punto Pure' at the Auto Expo 2016! Rajeevraj The Indian Car Scene 93 25th January 2017 22:59
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Swift VDI+ABS or Fiat Punto MJD or New Fabia 1.2 Diesel. Edit- Booked Fiat Punto MJD magnanimousdude Hatchbacks 59 27th October 2010 13:18
Fiat Grande Punto and the new Fiat Sedan; Tata-Fiat JV jkdas The Indian Car Scene 37 4th March 2009 17:01
Strange Swift Petrol Behaviour d_himan Technical Stuff 5 13th May 2008 14:59
