Old 29th September 2009, 14:07   #1
Default Fuel Tank Depression (Dent) in Esteem
Dear all,
I own a Maruti Esteem 2001 Vx , a year back i noticed a depression in my fuel tank,
This problem agrevated when my car would fail to start in a single start in morning or would all of a sudden stop in between when ever i passed a speed braker, this was due to the depression the fuel used to get accumulated on the sides of the tank providing minimum level in centre for pump suction
I got the tank overhauled, got the dent removed at a local mechanic;also notice the fuel pump line bent, he checked the breather line for any choke but found none, finally boxed up and problem resolved
However by the time i was back home and parked my car, out of curosity just checked the tank noticed the dent again
Now as the mechanic suggested i am planning to put some rods in the tank to maintain the shape of the tank
I need your advise, whether it is feasable to weld rods in the tank
Please help
SamirME01 is offline   Reply With Quote
Old 29th September 2009, 15:15   #2
pramodkumar's Avatar
Thanked: 947 Times
Rather than putting a rod inside, i would suggest put a skid plate. But i seriously you need to get your driving style checked. i have driven an esteem for 4 years and i have never heard of anything like that. Please go easy on speed brakers.
Pramod
Old 29th September 2009, 15:20   #3
esteem_lover's Avatar
Thanked: 451 Times
My M-800 had the same problem & it was rectified by blowing some high pressure air into the tank. The tank just blew itself back to shape like a baloon. I doubt this will fix the esteem tank though.
Replace the tank if it cannot be fixed.
Old 29th September 2009, 16:54   #4
Thanks for the Inputs Pramod and Esteem lover
However i would like to know by welding some iron rods on either side of the tank cover would not create any damage to my tank
EsteemLover could you please emphasize on Skid plate, it would be of great help
Old 29th September 2009, 17:59   #5
rr_zen's Avatar
Thanked: 268 Times
Instead of losing your sleep over this, I suggest you replace the fuel tank once for all. May be a relatively expensive option but will give you peace of mind for sure.
rr_zen is offline   Reply With Quote
Old 29th September 2009, 18:32   #6
ElantraGT's Avatar
Guys I was under the impression that all maruthi petrol tanks are made of Plastic. Is my assumption wrong. I beleive thats the reason why esteem lover's M800 tank just set itself right after blowing compressed air in to the tank.
ElantraGT is offline   Reply With Quote
Old 29th September 2009, 21:14   #7
rr_zen's Avatar
Thanked: 268 Times
I know for a fact that the M800's fuel tank is made of metal and not of plastic. I am sure the Esteem's tank is made of metal too.
Old 29th September 2009, 21:25   #8
kannan666's Avatar
Thanked: 70 Times
Yes, the older Esteem's fuel tank is definitely made of metal. My 1995 model has never faced this problem that is affecting Samir though and it has done around 1.02L kms to date. As I see it, welding iron rods on either side of the tank might create problems in two ways - one is that the rods itself might bend and poke into the fuel tank and two - in case you go over some protrusion on the road which gets in in between the rods, your fule tank is still under threat of getting an impact, I too would suggest 'skid plates' like rally drivers fix normally under the engine sump.
kannan666 is offline   Reply With Quote
Old 29th September 2009, 21:34   #9
fast_elegance's Avatar
Thanked: 89 Times
Originally Posted by SamirME01 View Post
Dear all,
Did you hit a speed breaker on your way back home or the dent just resurfaced on its own?
fast_elegance is offline   Reply With Quote
Old 30th September 2009, 08:56   #10
ElantraGT's Avatar
Thanks rr_zen. I stand corrected in this. Thanks for the info.
Old 30th September 2009, 10:11   #11
The dent has resurfaced on its own , as if the tank has caught up vaccum
Old 6th October 2009, 14:45   #12
Thanked: 451 Times
Both the M-800 as well as the esteem come with metal tanks, only that the metal is thin sheet metal & has the tendency to go out of shape very fast.
Old 6th October 2009, 15:20   #13
Thanked: 49 Times
I would suggest that you check the breather pipe again - the dent re-appearing points to a block somewhere that is causing a partial vacuum in your tank.
Do you hear a woosh sound (air rushing in) when you open the filler cap for refueling ?
CrackedHead is offline   Reply With Quote
Old 6th October 2009, 15:42   #14
Thanked: 31 Times
If you keep the tank to nearly 1/2 full then this problem will not come I guess. If yes then try keeping that level. It is not a good solution but can be used if you want to dispose off your car in near future and don't use it for long drives etc
aka_iitd is offline   Reply With Quote
Can the fuel tank capacity be increased speedsatya Modifications & Accessories 4 11th November 2009 09:31
Esteem fuel pump(mpfi) in esteem-carb tank techn0l0gist Technical Stuff 0 13th June 2009 22:03
MPFI Esteem missing with full tank. bhogalrajnish Technical Stuff 6 20th November 2007 17:58
fuel tank 42lt.- fuel in-44lt. v.tec Technical Stuff 55 29th August 2006 20:50
