Old 1st October 2009, 21:56   #1
rajivanoj's Avatar
Thanked: 45 Times
Default Fitting intercooler in lancer possible? - Advice needed
Can i fit Indigo's intercooler in lancer diesel, between the airfilter output and engine manifold, so that the air cools and will it improve performance and mileage? Is it feasible? Have anyone tried this?
rajivanoj is offline   Reply With Quote
Old 1st October 2009, 22:02   #2
Psycho's Avatar
Thanked: 95 Times
As far as I know it does not have a turbo to compress the air which would have increased the intake temps. The intercooler is required to drop intake temps, in your given case I dont see the need for one.
Old 2nd October 2009, 00:11   #3
reignofchaos's Avatar
Thanked: 1,169 Times
Lancer diesel is naturally aspirated. It has no turbo and an intercooler will be of no benefit to it.
Old 2nd October 2009, 00:18   #4
.anshuman's Avatar
Thanked: 8,929 Times
Thumbs down
Adding a intercooler to a non turbocharged car is a waste, no practical benefits.
Old 2nd October 2009, 00:40   #5
JayD's Avatar
Thanked: 1,996 Times
Rajiv, only turbo cars need intercoolers. Na cars do not. The lancer is NA, so there won't be much benefit from this mod.
Old 2nd October 2009, 01:08   #6
Thanked: 147 Times
Not all Turbos need Intercoolers. Case in point, the last gen Innova
Cyrus43 is offline   Reply With Quote
Old 2nd October 2009, 01:18   #7
Thanked: 52 Times
Depends on the boost the trubo is set to generate, earlier Indigos did not have intercooler, but tata added one intent 9bhp over the first generation turbos.
dinar is offline   Reply With Quote
Old 2nd October 2009, 19:51   #8
rajivanoj's Avatar
Thanked: 45 Times
Thanks all bhpians, i thought intercooler will boost something without turbo (so that cold air may make some positive change), anyways, i have dropped the idea. You people saved me from spending much without any final output.
Advice on fitting an air-conditioner in the Mahindra Thar DHABHAR.BEHRAM 4x4 Technical 318 27th November 2013 15:01
Suggestions needed for fitting Digi Speedo on Pulsar 150 rakowli Motorbikes 5 15th September 2013 11:36
Bigger Turbo/Intercooler on Bolero DI possible? vivekgk Technical Stuff 18 26th March 2010 07:24
car soft hood fitting- help needed lover_guy_001 Modifications & Accessories 4 30th July 2009 16:03
