Old 4th October 2009, 23:27   #16
In Linea, I think you can go for 16" rims and lower profile tyres (55 or 50).
Or even same profile can do (60) ... but you have to see if there's sufficient space in the wheel arches to accomodate the extra radius.
This would raise GC by 10mm or so I believe.
neotraveller is offline   Reply With Quote
Old 5th October 2009, 00:13   #17
AbhiJ's Avatar
Thanked: 536 Times
Originally Posted by patil View Post
even i own a i20 crdi asta o and i want to increase my cars ground clearence. will you please tell me what is the spec of the tyre u have upgraded to and is it causing any other problem such as touching the wheel arches etc.
185/70 R 14 instead of 185/65 R 14.
Zero problems.
AbhiJ is offline   Reply With Quote
Old 5th October 2009, 01:35   #18
EssYouWe's Avatar
Thanked: 16 Times
@AbhiJ
Are you using them? What price did you get for the originals and how much for the new ones?
EssYouWe is offline   Reply With Quote
Old 5th October 2009, 02:09   #19
AbhiJ's Avatar
Thanked: 536 Times
Originally Posted by EssYouWe View Post
@AbhiJ
Yup, using them happily. No issues whatever.
I drive on some insanely bad roads.
I swapped my apollo acceleres with XM1+. Cost around 6k incl. balancing.
Old 8th October 2009, 23:21   #20
maglev's Avatar
Thanked: 90 Times
Since you have said that the car would be delivered in a few days, which means that you are not facing the problem with your own car.
Instead you faced this problem in the Test Drive car which you drove.
To get it into the right prospective, I would like to know how many people were sitting in the TD car during the Test-Drive?? And there is always a chance of under inflated tires in the TD cars as they are misused / abused on a daily basis by both the prospective buyers and the showroom drivers. I would suggest then you wait for your car to arrive and then arrive at a conclusion.
maglev is offline   Reply With Quote
Old 8th October 2009, 23:36   #21
S.I.N.G.H's Avatar
Thanked: 40 Times
Default linea ground clearance
i agree with maglev's comment. but i cant understand one thing, why would the company keep the tyres under inflated? as this affects the pickup and breaking ability of the car.
regards
singh
S.I.N.G.H is offline   Reply With Quote
Old 9th October 2009, 03:30   #22
Singh
I can see you've not mentioned air pressure in tyre at all. What is the air pressure in tyres of the car you had driven?
Reason I'm asking is because I had taken Linea on real bad kinda off-roads which can not even be called roads off Lonavala. There were big stones, very big on the roads. Still Linea never scratched. GC is not great but its also not so bad either. can not see any other reason than Air pressure in tyres & load in the vehicle
VahanPujari is offline   Reply With Quote
Old 9th October 2009, 07:22   #23
kuttapan's Avatar
Thanked: 12 Times
Originally Posted by VahanPujari View Post
Singh
I would beg to disagree. I have a Punto and I would assume that GC is same for both. On bad roads, the underbelly definitely scrapes, now I know why there is a sump guard. My sump guard already has couple of scratches on it.
kuttapan is offline   Reply With Quote
Old 11th October 2009, 01:51   #24
maglev's Avatar
Thanked: 90 Times
regards
singh
Veeray,
The company does NOT intend to keep the tires under-inflated but the fact is that since Your Experience is Currently based on the Test Drive vehicle and it is very common for these cars to be driven very very roughly, not only by the showroom drivers but buy the prospective customers who may or may not buy the car. These cars go in for multiple test drives a day, which means that they are being driven hard through out the day and add to this the fact that most people tend to go on for Test Drives with there entire family, the tires are bound to be wrongly inflated and also take into account the dilapidated or weakened state of the suspension system due to the sheer number and extent of test drives taking place in one day.
Old 11th October 2009, 11:36   #25
S.I.N.G.H's Avatar
Thanked: 40 Times
Default linea gc
veeray,
thats soo true, now lets see what the real truth is. getting the car delivered on 15th of this month. lets hope for the best.
regards
singh
Old 11th October 2009, 14:30   #26
AbhiJ's Avatar
Thanked: 536 Times
Just remember, if you need to get the tyres swapped. Do it within a day or so of taking delivery of your vehicle... otherwise you ll get poor value for your oem tyres..
Old 11th October 2009, 18:02   #27
S.I.N.G.H's Avatar
Thanked: 40 Times
yea, i would prefer to do that. but i dont think that i'll have to swap the tyres. if i face problem with the GC, then only i'll get the tyres swapped or else the stock tyres are good!!
Old 16th October 2009, 08:14   #28
There are a few ways to increase GC..
1. You could go with a bigger sized Rim. I don't know the size of rims on a Linea. If its a 15", you could go for a 16" rim, long as you have a space between your tire and fender. If the space is too small, you will have to stiffen your suspension, but it makes your ride harder. In that case, you probably would not want to head that way
2. Lifting - the amount of lift must take into consideration length of shockers and brakelines, suspension angles etc. Its normally easy to add a 1" lift to your suspension.
3. You could add a tire with a bigger wall.. can be done cheap if you exchange your stock tires in new condition. That will prob add 5mm, although a small increase in GC, helps sometimes.
I have friends who have done some of these on their Jeep Wranglers, so take this with a grain of salt.
Congrats on your new car and happy driving!
pradeepkc is offline   Reply With Quote
Old 16th October 2009, 10:25   #29
amitoj's Avatar
Thanked: 1,691 Times
Singh Ji, congratulations on your new car!
Like others said, probably test drive car did not have right air pressure. I hope you are not facing any GC issues with your new car. Nothing worse than the sound of a brand new car scraping the speed breakers! If Linea has gc issues in your area, then you should probably be seeing honda civics doing see-saw on the same speedbreakers
amitoj is online now   Reply With Quote
Old 16th October 2009, 11:47   #30
kodivasanth's Avatar
Thanked: 22 Times
veeray,
regards
singh
How is your car doing and are you facing the low GC issue in your car too?
kodivasanth is offline   Reply With Quote
Official ground clearance upgrade package for Linea/Punto @ Rs. 10,000 akshay4587 Technical Stuff 102 22nd June 2018 18:02
Optimum ground clearance of a Car? & how it is measured... skamb Technical Stuff 84 17th May 2017 22:36
Raising a Tata Marina's Ground Clearance vivek.singh.73 Modifications & Accessories 27 8th September 2013 21:43
Please Help!!! Ground clearance of Fiat Petra 1.6 gets reduced deepgautam_qa The Indian Car Scene 6 22nd May 2008 12:10
