Old 2nd October 2009, 21:35   #1
Thanked: 152 Times
Default 800 Sudden power loss in Petrol/CNG
Today i was driving/acc at around 80 kmph in third gear in CNG when all of a sudden i felt a huge loss of power.I converted to petrol but problem remains.I brought the car to standstill and pressed the acc completely and i heard the engine is lugging even at stand still and rpm is varying continuously .So i ruled out clutch problem as the car should increase rpm smoothly atleast at standstill .I checked all pipes , everything is at place.
I am not able to move from standstill , it is a huge pain to get it up and running , the gears are fine .
Any help guys.
Trust_In_Thrust is offline   Reply With Quote
Old 3rd October 2009, 07:16   #2
mithun's Avatar
Thanked: 59 Times
Needs more info like Carb/MPFI, KMS ran, kit brand...
When posting a problem make sure that you provide necessary details...
Old 3rd October 2009, 12:39   #3
Thanked: 17 Times
Any help guys.
clean the spark plug, moisture must have gone inside. My zen had the same problem. MASS did the job free of cost
udaydesai is offline   Reply With Quote
Old 3rd October 2009, 22:08   #4
bj96's Avatar
Thanked: 130 Times
Originally Posted by udaydesai View Post
clean the spark plug...
+1.
800 has 3 inline cylinders. If any one (or more) spark plug is kaput, you will feel the power loss.
Some other causes of sudden power loss in a petrol engine could be following:
1. Fuel cutoff/exhausted- engine will die
2. Piston seizure (rare on modern cars)- engine will die.
3. Ignition circuit failure- engine will die
4. Spark plug failure- engine may not die
5. Clutch slips- engine will rev up w/o adding to car's speed
6. Stuck brakes
7. Air suction inlet jammed- engine will die
8. Exhaust pipe blocked- engine will die
9. Fork-lifted from rear (easy for a 800) as in some bollywood movies
-BJ
bj96 is offline   Reply With Quote
Old 3rd October 2009, 23:33   #5
Thanked: 152 Times
Update ; Problem solved . It was because of the timing.
Apparently the timing bearing failed .Around 4-5 balls of the bearing were missing.I was surprised as only around 4k kms i had the timing belt and bearing changed with MGP .
I have now a new timing belt , timing bearing .
Also asked the mechanic to check the head for any damages and lucky me there were none.
2007 Indica Xeta: Engine losing power all of a sudden and regaining power after mins mohandas Technical Stuff 17 3rd May 2016 07:37
Carb 800, loss of power at higher gears Perez Technical Stuff 17 4th July 2012 19:48
Swift : Sudden Surge in Power during accl and Kut kut sound at Braking lambuhere1 Technical Stuff 7 10th November 2009 15:01
will installing a turbo charger Compensate power loss from CNG Fl|rty Modifications & Accessories 19 10th September 2006 03:15
