Old 27th March 2010, 10:59   #16
Thanked: 53 Times
Originally Posted by nitrous View Post
Hi Dinar
I would trust Headers 99 times out of 100 when it comes to turbo charger model numbers.
I am not saying that he does or does not know about turbos, I just did not get the last post, That's it. I would like to know more about turbos and I understand that Header can not revel his source [I would not force him either] but I am confused as to what exactly he meant by common engineering. We are just trying to figure out turbo models that's it.
So If 1.4l, IDI engine [ indica/indigo] uses KP35 and the bigger IDI engines use K03.
@ header do you mean that K03 and KP35 are same turbos? And I do not mean the shaft, bearing, oil feed and external accessories, the impeller and turbine design wise.
dinar is offline   Reply With Quote
Old 9th April 2010, 07:28   #17
headers's Avatar
Thanked: 464 Times
@ Dinar: what i meant by common engineering is: if a TC1 has parts A1,B1,C1,D1,E1 and TC2 has A2, B2, C2, D2 etc.. it is not uncommon for a manufacturer to put together a TC3 with parts A2, B1, C1, D2 etc.
Hope you get it
Old 9th April 2010, 09:06   #18
Thanked: 53 Times
Hope you get it
Oh, Ok. I get it. May I ask which turbo India is built this way? you can Pm me if you do not want to disclose that too.
Cause I have finalized on a K03 for my project just have to desiced between water cooled or oil cooled.
Need help in identifying this Jeep? EDIT : It's a CL & MM Hybrid Driving_Nomad 4x4 Vehicles 12 28th June 2012 17:18
Need Help in Identifying this Jeep? EDIT : It's a fake Classic Acclero 4x4 Vehicles 15 25th January 2012 04:23
Need help identifying this Carb Gypsy-Boy 4x4 Technical 20 20th October 2009 10:59
Help required with identifying Background score... adit1329 Shifting gears 10 27th March 2006 19:46
