Old 21st May 2006, 04:35   #31
nitrous's Avatar
Thanked: 285 Times
5w50 has been tried and tested in Esteem 1.3Mpfi engine.
Its been used in a lot of engines.
So, u can go ahead with it.
Old 21st May 2006, 04:47   #32
nitrous's Avatar
Thanked: 285 Times
I've used 10w40 OWS in an Accent CRDi.
Felt smooth just after a 100 kms.
Old 21st May 2006, 08:05   #33
Rudra Sen's Avatar
Thanked: 4,288 Times
Another thread on synthetic oil running here.
Please note that this thread is merged.
Old 3rd March 2008, 15:19   #34
bluenest99's Avatar
Which engine oil do u suggest for optra 1.6 n of wat grade. Wat abt the one given out from GM. Can diesel oil like castrol CRB plus be also used for petrol engines?
bluenest99 is offline   Reply With Quote
Old 3rd March 2008, 15:35   #35
amit_mechengg's Avatar
Thanked: 1,556 Times
guys hows petronas Synthetic oil? its cheaper than other synthetics. cost 320 rs per litre. i have put it in my bike. i am finding it good. but please comment about using it in car. its fully synthetic 10W40
Old 6th March 2008, 14:18   #36
bluenest99's Avatar
what is the procedure to use engine flush?
Old 6th March 2008, 18:20   #37
nitrous's Avatar
Thanked: 285 Times
@amit: Synthetic oil in a bike can induce clutch slippage.
Moreover, 10W40 might not be fully-synthetic. Its most probably semi-synth.
Old 6th March 2008, 18:59   #38
Thanked: 29 Times
hi,
This is a good place to learn about engine oils.
Car Bibles : The Engine Oil Bible
Rgds
indianrunner is offline   Reply With Quote
Old 3rd October 2008, 16:40   #39
I have gone through the engine oil bible and other threads related to the comaprison of synthetic oils vs mineral oils. I have not seen a definite answer on this topic. I have swift petrol nearing 20k. I have to get the service done in a couple of days. PLZZZ help !!!! recommended oil is 20w40, mobil 1 does not have in this grade. I need some dealer addresses in bangalore for the engine oils.
thanks in advance
Originally Posted by indianrunner View Post
hi,
Rgds
prats is offline   Reply With Quote
Old 3rd October 2008, 22:38   #40
kailashnj's Avatar
Thanked: 281 Times
I need to know what engine oil to be used for Baleno. Its nearing its 40k Mark. Please people, let me know this is really urgent.
kailashnj is offline   Reply With Quote
Old 3rd October 2008, 22:50   #41
nitrous's Avatar
Thanked: 285 Times
You can use fully synthetic ,5W50/5W40 grade oil from Mobil1 or Shell Helix Ultra or Castrol EDGE or OWS for the baleno.
Old 3rd October 2008, 23:14   #42
kaushik_s's Avatar
Thanked: 156 Times
Today I've shifted to OWS 5w50 from Mobil1 0w40. Initial impression is quite nice, the engine is revving smoothly and the pickup also seems to be better(mind you, the previous oil was already more then 15k old, so the difference is noticeable). Flushing was done prior to changing the oil.
kaushik_s is online now   Reply With Quote
Old 4th October 2008, 08:55   #43
abhik's Avatar
Originally Posted by Gurkha View Post
Unless used in extreme conditions, the latest hydro-cracked HDEO group-II oils like Chevron Delo 400 or group-I with strong additive package oil like Delvac Super are turning up some incredible UOA readings, surprisingly better than synthetics, also it has been observed that HDEOs cause way less cam wear. Synthetics are good for extreme conditions, mostly sub 0 weather, the OCI factor is really not recommended here in India as the driving and dusty conditions play havoc on any oil.
The best results for gas or diesel cars can be obtained by using either Delo400 or Delvac Super and a conservative oil change interval of say 5000 miles. They are also very good value being way lighter on your pocket as well. Synthetics however do wonder to your tranny and there the cost is fully justified, sadly, it is truly hard to get synthetic tranny oil here in India.
So what you are saying is that i can use Delvac Super or Delo400 for my petrol run car as well? Have you tried it on a petrol vehicle.
abhik is offline   Reply With Quote
Old 30th November 2009, 10:45   #44
I am going for my 10K service for my Indica vista next week.So which is the engine oil that is most recommended for the tata motors indica vista
hdi.
hdi_pro is offline   Reply With Quote
Old 28th July 2010, 07:34   #45
Chetanya Sharma's Avatar
Thanked: 35 Times
Need an oil change for my 2002 Hyundai Accent 1.6 DOHC which has clocked 97,000 kms +. Oil is 5000kms + which also bore a rigorous 26 hr (1450km) drive from Mumbai a month back.
Is there any chance I can get Mobil 1 all synthetic extended range oil here in New Delhi?
Chetanya Sharma is offline   Reply With Quote
Engine Oil Change : Paid Service vs Buying Oil yourself vs Full DIY neosmart Technical Stuff 77 29th June 2017 11:16
What happens to the engine oil when the Oil cap and/or dipstick is opened? D.V.R Technical Stuff 29 19th September 2016 17:35
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
