Old 28th July 2010, 16:53   #46
dmaheshkumar's Avatar
Thanked: 18 Times
Default engines
When ur cars are alws used only for a long run means ,use 15w-40 ,20-40w.This will be bit thicker than the synthetic brands.
When the engine is getting heated(Long run) the oils will become like water.The thickness will change.Since here u r already using a synthetic oil means this will not good for engines for a longerlife.
Mechanical engines without CRDi technolgy will be only adviced to use 20w-40 (Non- Turbo) 15w-40 (Turbo engines).Even some CRDi users are also doing the same.
Castrol is also a good one for engines.
dmaheshkumar is offline   Reply With Quote
Old 7th November 2011, 07:46   #47
Catalyst_delhi's Avatar
Thanked: 149 Times
Default Re: best performance engine oil...
I drive a ford ikon 1.6 1.1 lac kms done. I usually drive long distance and around noida / indirapuram. I presently use 20w50 but manual says 5w30. I personally feel that 5w30 is too thin for an old engine.
I am inclined to use helix / magnatec for the next time around. Please advise which oil I should go for. Last change was done by carnation this time , I am doing this my self. thanks
Catalyst_delhi is offline   Reply With Quote
Engine Oil Change : Paid Service vs Buying Oil yourself vs Full DIY neosmart Technical Stuff 77 29th June 2017 11:16
What happens to the engine oil when the Oil cap and/or dipstick is opened? D.V.R Technical Stuff 29 19th September 2016 17:35
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
