Old 4th October 2009, 17:27   #1
genesis's Avatar
Thanked: 309 Times
Default Strange Noise From Innova Tyres (Kttrrrk)
Over the last month plus, the stock tyres of my innova (especially the rear right) one occasionally makes a kttrrrk (no better way to describe it ) kind of noise. There was no pattern or predictability of the noise.
(For those who have driven in the US, it is the kind of noise one gets when you stray onto the shoulder of a freeway.)
Yesterday while on the Mumbai-Pune-Bangalore highway, the sound repeated with more frequency. This time also from the front left. But again there is no pattern and then it did not reoccur.
I need to get my tyres replaced anyway (tread is starting to run low) but am baffled by the sound.
Any inputs are appreciated.
genesis is offline   Reply With Quote
Old 4th October 2009, 18:28   #2
Check if the noise is coming only on a particular stretch of a Road. I have noticed this on couple of streches when this happens and this is due to the nature of the road
FlairBoy is offline   Reply With Quote
Old 4th October 2009, 19:24   #3
blackasta's Avatar
Thanked: 1,156 Times
Maybe something somewhere is hanging loose (inside the wheel fender / bumper) and hitting the rims/tires. Maybe the mudflaps?
blackasta is offline   Reply With Quote
Old 5th October 2009, 14:57   #4
Thanked: 103,333 Times
You need to check the tyres for damage first. Your post seems to indicate that they are well worn.
If the tyres are okay, something seems to be rubbing against the tyre. A loose mudflap or the (inside) fender cover perhaps?
Old 5th October 2009, 15:25   #5
blackasta's Avatar
I had a problem of this sort when I upgraded tires in i10. While backing up and the steering fully turned, the grooves in front tires caught edge of the front mudflap and gave a 'kat-kat-kat' sound.Though it was a 2-3 mm overlap, I removed the front mudflaps. The sound is now gone. Anyone has any idea of recessed mudflaps or something like that? My mudflaps came factory fitted.
Old 5th October 2009, 17:07   #6
genesis's Avatar
Thanked: 309 Times
I think the loose mudflap theory is a good one to investigate. Seems to make sense. Tyres are also due for replacement soon but they are not in terrible shape. (Yoko C drives are being eyed )
On a related topic I remember reading somewhere (cant remember where) that in some tires once the tread passes a particular limit there is a warning sign/signal to alert the user. That was another theory in my mind but google did not throw up anything.
Old 5th October 2009, 17:41   #7
Thanked: 31 Times
Try peeling off some portion of your mudflap and see if it solves your problem
aka_iitd is offline   Reply With Quote
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Strange noise from Indigo. sajo Technical Stuff 12 7th May 2007 11:59
Strange noise from speakers Vivekphadnis In-Car Entertainment 25 22nd January 2006 00:12
Strange noise from 800 DCEite Technical Stuff 7 5th November 2005 11:33
