Old 5th October 2009, 01:33   #1
ricky_1605's Avatar
Thanked: 47 Times
Default Matiz water leak in car
Hey guys
I have noticed water on the floor of front passenger seat and rear seats and i think it is leaking because of the AC. I cudn't see from where the water was leaking. All the floor mats get wet and it starts stinking. help me.
ricky_1605 is offline   Reply With Quote
Old 5th October 2009, 09:12   #2
hvkumar's Avatar
Thanked: 3,365 Times
Left hand side, below the glove box, you will find a rubber tube fitted into a metal tube. Check if it has come off, that is the cause for the AC water to flow inside.
hvkumar is offline   Reply With Quote
Old 28th December 2009, 11:47   #3
Daewood's Avatar
Thanked: 223 Times
Also during rainy season water leaks into Matiz through the roof antenna.
As the antennas age and the gap between it and the roof becomes more, this happens. The water drops fall onto the gear-lever leather casing and depending on the position of the gear, sometimes flows to the front passenger side or onto the cup holder.
This can be rectified easily by using a new rubber washer for the antenna.
Daewood is offline   Reply With Quote
Strange water leak in my car pawan_pullarwar Technical Stuff 27 30th November 2015 12:27
Scorpio SLE Water leak - Thank you Mahindra & TVS ninanjohn Indian Car Dealerships 5 16th January 2012 08:38
strange water leak via door in ZEN skyliner34 Technical Stuff 12 27th April 2011 17:37
New Swift Diesel - Water Leak through front Windscreen and the following messup!!! sam_sant2005 The Indian Car Scene 71 24th December 2010 17:02
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
