Old 5th October 2009, 16:46   #1
Question Strange braking (juddering) sound
I own a Swift LDI bought in 2008. The problem, which I have been only recently noticing, is that if I break hard then i hear a very bad juddering sound as if some metal part are hitting against the road or something... The car vibrates at this time and there is loud noise with the feeling that some car part is creating friction somewhere. This does not seem normal. Any hints?
This is embarrassing when I have some guests sitting with me and am showing off my Swift
skumar69 is offline   Reply With Quote
Old 5th October 2009, 17:27   #2
coolclouds's Avatar
Thanked: 514 Times
Long back, while traveling on a just tarred road, a small metal piece stuck to the brake pad with tar which created similar sound while braking. May be anything such?
coolclouds is offline   Reply With Quote
Old 5th October 2009, 18:12   #3
But, if something had stuck to the break disks, then I assume the noise would have come whenever i used the breaks. In my case, the noise comes only when i break hard.
Old 5th October 2009, 18:28   #4
ElantraGT's Avatar
@Skumar69 - Are you sure this is not the sound from the ABS in action. In my elantra when the ABS comes in to work, I hear the vehicle shudder as the brakees are released and reapplied by the ABS.
ElantraGT is offline   Reply With Quote
Old 5th October 2009, 18:35   #5
Unfortunately, my car is not equipped with ABS as it was too expensive for me that time :(
Old 5th October 2009, 18:39   #6
ElantraGT's Avatar
Ohhhhh thats bad then. When was the last time your vehicle was serviced? Did you check the break pads for wear and tear?
Old 5th October 2009, 18:42   #7
recshenoy's Avatar
Thanked: 104 Times
Arrow
our zen had faced similar problem, noise of metal rubbing was heard while applying brakes. Brake was very week suddenly. Same day after some Kms, the front disk assembly came out
my brother took it to M.A.S.S and got disk replaced
Please get it checked from M.A.S.S on priority. Not sure what had happend as I was abroad that time
recshenoy is offline   Reply With Quote
Old 6th October 2009, 10:30   #8
coolclouds's Avatar
Thanked: 514 Times
My friend's accent showed similar sound but got rectified by changing the brake pads.
Old 6th October 2009, 11:05   #9
Thanked: 25 Times
Please get the car checked and do not drive fast till the problem is fixed or someone will be heading to hospital. :(
supercars is offline   Reply With Quote
Old 6th October 2009, 11:17   #10
gigy's Avatar
Thanked: 41 Times
Showing off swift to guest by braking hard!!! you are putting others to risk.
Get it checked by MASS immediately, least others loose their life and property. Could possibly be due to cracked pads or cracking assembly itself.
Old 6th October 2009, 12:09   #11
Showing off my Swift by breaking hard is just not my driving style. But, it so happened that while I was elaborating on the greatness and features of Swift, I had to break hard due to some reason. That is when this happened and all my greatness talks evaporated away.
Anybody knows how long is Swift under warranty?
Old 7th October 2009, 02:04   #12
IndrojitSircar's Avatar
Thanked: 116 Times
Well it has a three year extended warrenty which is built into the on road cost.I think its the break pads beacuase when you hit it hard then the complete break pad hits the disk and the worne out in portions and may have caused gaps due to which you get these judders.If you just hit it slowly then only a portion of the shoe ie the part with maximum grip could engaging and you not having this.This could happen because of normal wear and tare.
Old 7th October 2009, 02:12   #13
humyum's Avatar
Thanked: 2,502 Times
It has a 2 year company warranty which can be extended by another 2 years.
Try it on different road surfaces too, might be because of uneven bouncy roads too.
If it is juddering all the time, get the brakes bled, disc cleaned, pads cleaned and then try again. A warped disc wont come under warranty and u ll have to get it skimmed with the pads replaced.
Old 7th October 2009, 02:15   #14
Thanked: 116 Times
Well i think it has changedi bought my swift in june and i paid for 3 years extended warrenty along with one year company warrenty.
Old 7th October 2009, 02:26   #15
humyum's Avatar
Aing, thats strange, i got mine in december and i have 2 years company warranty and 2 years extended.
One year company warranty only, sheesh , maruti whats up, when the competition is giving such hi fundu warranties, this move by maruti surprises me !
Strange noise when braking Vajo Technical Stuff 25 3rd March 2017 21:28
Strange loss of braking ability. What happened? msdivy Technical Stuff 86 30th August 2015 01:00
Brake Pads "cheen-cheen" Screeching Sound While Braking vebmetal Technical Stuff 74 16th February 2013 07:26
Strange Braking issue with the Esteem amohit Technical Stuff 6 9th February 2012 18:00
A strange sound while braking zaks Technical Stuff 2 11th February 2009 22:24
