Old 5th October 2009, 16:54   #151
Unhappy Foul Smell from Blower / Fan in swift
I have a Swift LDI bought in 2008. It has been bought with great love and is admired by both me and my wife. The problem is that from the day 1, if we put the AC on 'fresh air' instead of internal circulation then the air comes in with a very bad smell as if something is rotting. So, my wife never lets me turn on fresh air and we are always on internal cirulation and AC...even on superb cool/rainy days. Using ambipure now, but still.... as soon as the AC mode is turned to 'fresh air' the air starts smelling bad.
Any clue why this might be happening and how I can rectify it? 'Fresh air' should be fresh, right?
skumar69 is offline   Reply With Quote
Old 5th October 2009, 17:01   #152
greenhorn's Avatar
Thanked: 1,519 Times
something dead/rotten in the tubes? you might want to check the ducts
http://www.team-bhp.com/forum/techni...fan-swift.html
greenhorn is online now   Reply With Quote
Old 5th October 2009, 17:06   #153
Rudra Sen's Avatar
Thanked: 4,295 Times
Mods note: Thread merged.
Old 5th October 2009, 17:07   #154
maglev's Avatar
Thanked: 90 Times
As Greenhorn has suggested getting the ducts checked would be a good idea. In your case since the car has this problem since the beginning it is highly possible that something dead or rotten is blocking the External Air Inlet.
maglev is offline   Reply With Quote
Old 11th October 2009, 03:38   #155
frankmehta's Avatar
Thanked: 2,334 Times
no CONCRETE solution yet? I am sure it will be a HELL of a job to explain this resistance business to the a holes at the A.S.S for most of us.
And others who want to get it done outside will risk voiding their warranty.
God, I wish they addressed such issues at birth.
frankmehta is online now   Reply With Quote
Old 12th October 2009, 00:42   #156
Parm's Avatar
Thanked: 611 Times
first of all STOP USING car deo/perfumes in your vehicles as they only mask the smell and are not the solution for bad and foul smell!
usually the smell comes from the bacteria and fungi which develops and breeds in the evaporator coil of your AC, located behind the central AC vents of your vehicle.
evaporator is the perfect breeding ground for the bacteria and fungi because its dark and moist out there, which helps them breed!
the air from the blower motor passes through this evaporator coil into your cabin.
i would give you a simple solution and do this once in two weeks.
open all windows of your car.
run your AC blower motor on full speed with temparature setting on HOT.
every five minutes change the air flow setting from front to foot to windscreen.
the air flow setting should also be changed from re-circulation to fresh air.
AC should be OFF all along this process.
this process should be carried out for atleast 15-20 minutes every two weeks (twice a month).
the hot air dries the evaporator coil and kills all the bacteria and fungi, because they cant survive in heat!
see the same way we open the windows and doors of our house to let the fresh air circulate in our house, we hardly do it with our cars!
some people smoke inside the car with AC running!
some people use perfumed scents/deos/air freshners....STOP using them!
all the smoke and air freshners get stuck in the evaporator coil and keep giving you bad smell after a while.
also always do this> when you are 1 km from your house, switch OFF the AC and let the blower motor run till you reach your house.
this will make sure the evaporator coil dries with the air from blower motor and will not cause bacteria and fungi breed in the evaporator.
if your car has a cabin filter, get it cleaned/dusted out in every service and change it as and when required.
we had a case of bad smell with a customer, it was later diagnosed that there was a cat around the area he use to park his car and the cat loved sitting on the bonnet and use to pee over it near the front windscreen and all the pee dripped down to the fresh air intake of the blower motor.
another case was of a rat being found dead inside the fresh air intake.
any Questions about this, discuss here and dont pm, that way others will also learn few things about maintaining hygine inside the car.
Parm is offline   (1) Thanks Reply With Quote
Old 12th October 2009, 21:58   #157
s3va's Avatar
neat advice !
Additionally the 3M bacteria/fungal removal solution can be used once in a while to ensure there is minimal organic activity in the vents.
Last edited by Jaggu : 27th October 2009 at 10:08. Reason: Avoid quoting entire large post for short reply, thanks
s3va is offline   Reply With Quote
Old 27th October 2009, 05:51   #158
sswami4's Avatar
Default Stinking A/c in SX4
Hi Guyz,
My Sx4 A/c Stinks Everyday , the First time i start the car, It has done 6000 kms.
Ive put 2 air freshners On either sides (godrej Ambi pur )
But none seem to be workin.my car has been driven only in A/c From Day 1,Hardly remember opening the windows.
Please Advise what needs to be done & what shall be the sureshot Car Aroma brand i should put in ?
Thanks in advance,,..
Ravi Patel
Last edited by Jaggu : 27th October 2009 at 10:08. Reason: Please use search before opening a new thread, Thanks
sswami4 is offline   Reply With Quote
Old 27th October 2009, 08:26   #159
BenjiRoss's Avatar
Thanked: 167 Times
What is the stink like - a dead rat/lizard, wet cloth kind of stink? Smoke? Fuel smell? Find the source rather than just use perfume to try and nullify it.
BenjiRoss is online now   Reply With Quote
Old 27th October 2009, 08:58   #160
tabrez02's Avatar
I would suggest get it check, if some water has gone inside or some animal like rat, you should get it checked at MASS.
tabrez02 is offline   Reply With Quote
Old 27th October 2009, 09:54   #161
rkbharat's Avatar
Thanked: 613 Times
besides other's suggestion, this sometimes happens, when some food items thrown in to the vent, very common with kids, and its start rotting giving foul smells.
I guess get it checked at MASS
rkbharat is offline   Reply With Quote
Old 27th October 2009, 10:03   #162
shankar.balan's Avatar
Thanked: 5,350 Times
small rodents like rats, squirrels etc find cars a comfortable place to nest - could even have had a litter of babies inside and maybe one or two of these perished inside.
Suggest that you have the complete AC dismantled and the dash board facia taken apart to locate the problem - have it completely cleaned up and then install a rat proof mesh to prevent these things in future.
These steps are slightly painful but better to prevent such occurrences in future.
Old 27th October 2009, 23:11   #163
sierrakamat's Avatar
Thanked: 75 Times
i had a similar problem with my tata estate which gave off a sour chemical like smell as soon as the ac was turned on finally was linked to the alternator overcharging the battery which was emitting gas which was being sucked by the ac into the cabin.
sierrakamat is offline   Reply With Quote
Old 30th November 2009, 19:56   #164
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
is there any member in this forum with a Chevrolet spark who has encountered smell from the AC vents? the reason why i am asking this is one of my colleagues who owns a spark has complained to the A.S.S. several times regarding the pungent odor coming from the vents but the Service team are unable to provide any solutions denying there is no incident of AC smells from Sparks sold, if there is anyone who has come across this problem please let me know what actions have been taken against it, this will be a relief to my colleague who is planning to sell his spark because of this niggling issue,
Thanks in advance
SPIKE ARRESTOR is offline   Reply With Quote
Old 1st December 2009, 09:59   #165
Thanked: 63 Times
For me in swift, If I get the foul smell, I keep my car windows open and run the AC full flow on hot condition for 2 mins. Then make the temperature to neutral for a couple of mins and then cool it with windows closed. It worked for me all the times.
Try it out in Spark and see if it helps
lambuhere1 is offline   (1) Thanks Reply With Quote
Noise from AC fan in Swift. Only Blower speed IV works! rajeev k Technical Stuff 10 25th July 2011 22:13
Weird Sound in AC Blower Fan in Swift petrol Endofdayz Technical Stuff 16 7th May 2011 18:46
Honda Jazz Foul smell issue devarshi84 Technical Stuff 9 22nd February 2011 14:19
Air Filter for A\C Blower Fan??? enigmatictech Technical Stuff 0 17th December 2008 13:15
