Closed Thread
Old 21st July 2005, 13:21   #1
chandan's Avatar
Thanked: 46 Times
Unhappy poor headlights in Getz !!
The headlights in Getz is insufficient for highway driving.....55/60 w bulbs.But the spread is great...just the brightness.Remedies ...????
chandan is offline
Old 21st July 2005, 14:16   #2
Rehaan's Avatar
Thanked: 25,043 Times
Most headlight problems are just badly aligned lights.
Even the best headlight, if not set up correctly can be a dissapointment.
Make sure your height is adjusted correctly, its possible that your headlights are aimed too close, in which case things further away are not being lit sufficently.
Or alternatively, they could be aimed too high, in which case the max of the beam is being projected straight ahead and not really lighting up the road (and just blinding oncomming traffic.)
A rough test to check -
Drive up facing towards a wall at night. Stay about 10 feet away from the wall and notice the horizontal line (of light at the bottom and dark on top) that your headlights create.
This line should be a couple of inches lower than the level of the bulbs.
This is just a rough test, but it might make the problem clear to you if it is an alignment problem.
Let us know.
cya
R
Rehaan is offline
Old 21st July 2005, 17:03   #3
speedsatya's Avatar
Thanked: 712 Times
you can upgrade to 90/100w bulbs.but for that you have to fit a relay.
or else you can go for the new philips vision plus 55/60w bulbs which claim to give 50% more light.
but before that ,make surethat your headlights are aligned properly.
speedsatya is offline
Old 3rd July 2009, 11:37   #4
nishantgandhi's Avatar
Thanked: 151 Times
Is it possible for the headlights to get de-aligned over time? I recently upgraded to 90/100w and my mechanic says the install can no way be blamed for poor beam focus. That problem would have existed even on my 60/55w. However, I am pretty sure the older bulbs were aligned properly.
nishantgandhi is offline
Old 3rd July 2009, 12:01   #5
Thanked: 16 Times
Put Philips Extreme power bulbs of the same wattage if you are not going for rally bulbs. I have been using them for past 1 yr in my Verna without any problems and I feel them adequate.
Prass is offline
Old 3rd July 2009, 21:03   #6
Akshay1234's Avatar
Thanked: 7,243 Times
of course its to be blamed. same thing happened to me after i changed the bulbs. focus got messed up and still is.
Akshay1234 is offline
Old 4th October 2009, 11:29   #7
DriveTrain's Avatar
Thanked: 311 Times
You are correct , the stock headlights are woefully inadequate. I changed to Osram Nightbreakers , they have the same wattage as the OEMs 55/60 and did wonders. I did not wish to go for 90/100 as new wiring harness would have been needed.
DriveTrain is offline
Old 5th October 2009, 16:10   #8
teknophobia's Avatar
Thanked: 22 Times
Osram nightbreakers are excellent bulbs in the dry, but you will have some problems during driving in the rains, however I guess the tradeoff is worth it . I personally feel that the Xtremepowers give me better visibility in the rains.
teknophobia is offline
Old 5th October 2009, 17:23   #9
Thanked: 21 Times
Today I got the relay and the wiring harness installed in my Getz CRDI. The relay used was a PMP brand and the only uncomfortable thing which had to be done was , the two caps which were closing the light holders had to be drilled to the size of a reynolds pen and then the wires had tobe taken through those holes.
I know the installer personally well and can vouch by the quality of his workmanship, hence went ahead with this upgrade as the quality of the stock headlamps was awfully inadequate especially in the highways.
Th total cost for this setup costed me INR 800 inclusive of his installation charges.
Kaushal
mjkaushal is offline
Old 5th October 2009, 19:03   #10
ElantraGT's Avatar
@mJkaushal - Why did you need drilling in to the fixture. By the way what wattage bulbs are you using?
ElantraGT is offline
Old 5th October 2009, 19:38   #11
mdesai_1981's Avatar
just wanted to know if i installed the 90/100 bulbs in my NHC will it spoil the headlight assembly glass(actually it is not glass but some glasss sort of material) please advice as i have see most of the cars with upgeaded bulbs tht they fog up.
mdesai_1981 is offline
Old 5th October 2009, 19:42   #12
Technocrat's Avatar
Thanked: 2,589 Times
This is an old thread Please continue all lighting discussions in This Thread
Thread Closed
Technocrat is offline
Closed Thread
State of plastic fitments on cars : Poor quality or poor maintenance? libranof1987 Technical Stuff 10 15th January 2011 21:14
Gear Lock and Headlights for Getz nishantgandhi Modifications & Accessories 21 6th August 2010 01:43
Getz Prime Headlights. Upgrading to Xenons.Help needed wmax Technical Stuff 17 3rd February 2009 16:20
Getz prime 1.3 is overpriced than previous getz ( old one )? hrishig The Indian Car Scene 3 30th April 2007 10:29
Getz New Launch + Getz vs Swift.. scorp 1 Hatchbacks 18 23rd August 2006 11:34
